IH CPS part #. replace your grey or black CPS with this one!!
Old Jan 26, 2010 | 06:33 PM
  #46
Action4478's Avatar
Action4478
.....1.12.....
Old Jan 26, 2010 | 06:40 PM
  #47
F350-6's Avatar
F350-6
I'm wondering if this has changed again too. Here's from my thread (similar to the one from Curtis) some time back.
Black C99 IH CPS vs. "new & improved" gray CPS from the Ford house
Old Jan 26, 2010 | 07:15 PM
  #48
MADVAN's Avatar
MADVAN
Originally Posted by Action4478
.....1.12.....
And with the raised epoxy dots?
Seems some were raised and some were not.
My mind is shot with the chemicals.
Chris
Yours do show the .020 diff
Its what i have found also.
The install of the grey sensor will add .020 to the air gap.
IH spec is .025 to .030 air gap.
Bill
Old Jan 26, 2010 | 07:32 PM
  #49
strokin'_tatsch's Avatar
strokin'_tatsch
Bill, i will get pics when i get around to pulling it back out. i gotta get my wheel bearings and rotors and all fixed before i screw with the CPS again. haha
on edit: i don't have cool tools like Chris has, btw..
Old Jan 26, 2010 | 09:42 PM
  #50
Talyn's Avatar
Talyn
I miss seeing chris around here.
Glad I have cool tools. =)
My dial calipers got stolen though with my brief case 5 years ago.
Old Jan 26, 2010 | 09:46 PM
  #51
Knotwild's Avatar
Knotwild
I will surely be grateful if someone posts IH CPS installation and shimming instructions for dummies once this all comes together. I think my truck has the original CPS at 197,000 miles and I do have some hard cold starting and a few times lately my truck feels like it cuts of a millisecond or so while driving at normal temps. Plus I am a true novice shade tree mechanic; which means I have to brush the dirt off my back when working under my truck.
I ALWAYS respect and appreciate Bill's knowledge! Thanks Bill. And also my thanks to the others who posted pictures and explanations.
Old Jan 26, 2010 | 10:07 PM
  #52
strokin'_tatsch
heck i just threw this one in and runs good. i'm going to have to see if someone around here knows how to set the air gap b/c i have no clue. LoL. i don't have calipers or anything, but when i stop at the parts store tomorrow for rotors i will see what they got. probably nothing good though.
Old Jan 27, 2010 | 12:45 AM
  #53
Talyn's Avatar
Talyn
if you were good with a set of dial calipers, you could do this measurment, if you could get them in there that is.
If you coudln't, a machinists rule will do the trick also.
Old Jan 27, 2010 | 09:10 AM
  #54
MADVAN's Avatar
MADVAN
Come on now Travis.
All i can get my hands on is the older grey.
Bill
Old Jan 27, 2010 | 09:27 AM
  #55
Action4478's Avatar
Action4478
Chris
Bill
Bill, two dots , (makes it harder to measure), about1.14...
Old Jan 27, 2010 | 09:40 AM
  #56
MADVAN's Avatar
MADVAN
I hear ya. Not accurate. But its a ballbark.
I have seen some psd's strike the epoxy.
Bill
Old Jan 27, 2010 | 11:00 AM
  #57
Copedawg's Avatar
Copedawg
I just checked some codes and here is what I found:
0344 CMP Camshaft pos sensor ckt intermittent Incorrect number of CMP transition counts Harness routing, charging ckt, sensor, int ckt, improper gap. I replaced the CPS about 2+ months ago....would this code still be there?
0475 EPR Exhst press control valve malfunction Exhaust back pressure regulator - KOEO OCC test Open/grounded ckt, solenoid open/shorted, failed PCM (I have this unplugged)
1280* ICP ICP circuit out of range low Uses inferred ICP strategy Open/grounded circuit, biased sensor, PCM (I put in 2 10 pots but I removed them months ago)
BIG THANKS TO BAZ! Tips - Idea - Hints
1395 I believe this is a GP problem.
I cleared the codes and I will check them again tomorrow and next week.
Old Jan 27, 2010 | 11:19 AM
  #58
97250hd-earl's Avatar
97250hd-earl
I had trouble in late dec, it was comming up with cps codes and other things , turned out to be shorted wire under the vc, replaced them cps still had codes, went to ford got shims for the cps and the codes went away the shims part # isf7tz-12j072-aa it had 2 shims in it and i put both in. as for info on the cps i found the that the coffee book on ford was very good ,since i have not figure out to post things yet i have to do the hard way, go to FORDDOTORSD+S.COM click on coffee table books - click on 98-99.5 7.3dit go to page 32 new and revised sensors, page 33 cps, page 46 cps parts suffix summary and other things that will help every one of to understand things we would like to know ,
Old Jan 27, 2010 | 11:24 AM
  #59
Copedawg's Avatar
Copedawg
Thanks for the link, unfortunalty Uncle Sam won't let me look at it. I will check it out when I get home.
Old Jan 27, 2010 | 11:35 AM
  #60
97250hd-earl
copedag--code 475 the tube that runs from the end of ext monfold on the pass side is probably pluged it run up to the epr sensor
