lifter replace
Yup gasket is there and added some grey RTV - the EGR is now tighter than a bulls butt in a fly season. Double checked everything else - the engine is still running extremely high. I did not touch the distributor, simply put in new plugs. What am I missing ?
I thought the same thing - disconnected the TPS and unhooked the throttle cable - still mad rpms :/ its loud as hell so not having any luck listenning for a hiss
Unfortunately, I'm not very well versed in EFI, so my help stops at vacuum leaks and cracked gaskets.
However, you did just have everything apart, so it must be something you removed/touched, etc. Did you use all fresh gaskets when you put the intake back on? Check to be sure all the sensors were plugged back in?
Thanks again !!!!!
Before
After - the last 2 rockers had a crapton of rust and set in varnish, didnt come off very well
Quick note - if you want your engine internals to shine like the Cylinder 2 rockers then mix 2 quartz of full strength purple power with Heavy Duty Engine Degreaser aerosol from the can and watch the "scrubbing bubbles" action. Took about 2 mins to eat the varnish and the metal container it was in
Very nice! Glad to hear it.
I'm glad you got the help you needed. I know I've learned just about everything I know from the willingness of people on the forums to share and help. Saved a fortune too! So it's great to give back.
The best you can do now is just go through a regular break in procedure for the lifters. Can't change the fact that the engine revved up, so just move forward.
I've seen much worse sludge than that, but that's pretty dirty. Nice job on cleaning it up.
My brother's Jeep 4.0 blew, and when we lifted the valve cover off, it looked like it was filled with brownie mix that had cooked in place. 1/2" deep in places!
Well..I happen to have a 4.0L Jeep - going to get the mechanic boroscope to see under the cover. On a side note - already did the 2k (guessing) RPM for 20 mins run. What else do I need to do to break in the new lifters? I did add a drop of oil mixed with MMO into each and compressed it by hand a few times before caking the outside in break in lube before installing them.
I think that's about it. It just mates the lifters to the cam lobes.
I'm not sure what happened to my brother's jeep. He bought it used and it must've had some terribly poor maintenance because those are good engines.
Best of luck with your engine now. Be nice to get all that stuff cleaned out and have it all shiny inside again.
Lifter replacement
Glenn
It runs smooth as butter, no more ticks, I am dropping oil pan today to seal a leak then just need to figure out whats up with excessive shake in the shifter stick, guessing motor mounts but they dont look bad.
BaronVonAutomatc
Mar 2, 2016 06:36 PM
Milpool
Jan 31, 2016 10:13 PM
