Steering Column replacement
Old Jan 24, 2010 | 10:14 PM
zswiss182's Avatar
zswiss182
I'm wanting to replace the steering column on my 85 ford f 250. The actuator rod is broke, the tilt column has had some play in it for some time, the blinkers don't lock into position ( I have to hold them down manually for the duration of turns) and I've been told that switching to a non tilt auto column would be best. That being said, I was wondering if it is a fairly straight forward removal and installation, or are there procedural issues that I would be better off being aware of??
Thanks,
Jeremy
Old Jan 24, 2010 | 10:48 PM
first today's Avatar
first today
I would go back with a tilt. There are plenty in good condition in the junkyards. We just swapped my dads over from straight to a tilt. It is no big deal to use either column.
Old Jan 25, 2010 | 12:04 AM
zswiss182's Avatar
zswiss182
How did you go about taking it out? Is it as simple as dropping the column, unplugging it, and removing the bolt that connects it to the steering shaft?
Old Jan 25, 2010 | 12:20 AM
first today
That easy.
Old Jan 25, 2010 | 01:48 AM
zswiss182's Avatar
zswiss182
Alright, that is what I was hoping to hear. Thanks for the help!
arrowheadfred
Aug 29, 2010 08:03 AM
turner45
Jan 24, 2008 06:50 PM
dfwdiesel
Dec 13, 2007 09:08 PM
rews2
1978 - 1996 Big Bronco
Apr 12, 2006 10:23 AM
Ladz
Jan 16, 2006 07:25 AM
