Tilt steering location
Old Aug 27, 2010 | 08:25 PM
arrowheadfred's Avatar
arrowheadfred
I was hoping some of yall that have tilt column would tell me were it needs to go. In the floor or the firewall and how much drop did yall use.
Old Aug 27, 2010 | 08:43 PM
52 Merc's Avatar
52 Merc
Too many variables to say given your information here. It's also a very personal preference depending on your seating arrangement. Ideally, you want the bottom pointing toward your steering box shaft, and the wheel in a comfortable position for you when you sit in the seat. If you can figure all this out, the column will fit where it fits.
Old Aug 27, 2010 | 09:06 PM
arrowheadfred
location
I understand all this wayne. I don't have a seat in my truck. I was hoping a few folks that have there trucks put back together would tell me how it worked out for them.
Old Aug 27, 2010 | 09:21 PM
52 Merc's Avatar
52 Merc
Well, Fred, I'm glad you understand that it's important to follow the correct sequence of events for installing your steering column. Typically, those who put the column in before the seat has had to redo their column mounting when they realize it doesn't work like they wanted it to. I'd hate for you to be one of them.
Old Aug 27, 2010 | 09:28 PM
eman92082's Avatar
eman92082
There's no getting around what 52 Merc said. If you "understand" all that then you'll mock up your seat and determine where it should go. Bonus Built Cabs aren't real big inside and you'd be surprised how much difference an inch makes in any direction.
In respect to drop, a great of that depends on your height and your belly (or lack of) I'm not being a smart-a$$. These are real issues to consider.
Good Luck
Old Aug 27, 2010 | 10:35 PM
arrowheadfred
location
lol lol lol NOW thats funny !!! But what is so hard about saying HEY FRED i have a tilt column and i put it in the floor OR HEY i went in the firewall.
Old Aug 27, 2010 | 11:16 PM
eman92082's Avatar
eman92082
It's not a matter of it being hard to say. It's about giving you the best answer possible from our experience. If you are connecting to a steering box in the stock location, it's gonna route through the floor where the stock column was mounted. If you're running another box in another location you'll need to possibly determine exhaust clearance issues and the angle that best suits your connection scheme safely. If that means going through the firewall then that's what you need to do. Each application is unique.
Old Aug 28, 2010 | 06:28 AM
GreatNorthWoods's Avatar
GreatNorthWoods
On the two trucks I've done, one a 48 and the other a 49, the column went through the floor slightly higher than where the original column went, however, I used a 90 Ford Ranger seat in one and a 95 Mazda pickup seat in the other with a Volare box. Your seat selection and how you mount it will definitely make a difference. The two seats I used had thinner backs and I modified the seat mounting to lean them back a lot more than the original seat...
Old Aug 28, 2010 | 07:27 AM
jniolon's Avatar
jniolon
old and in the way
fred
this might help
http://www.clubfte.com/users/jniolon...tsteering.html
and the redo
http://www.clubfte.com/users/jniolon...columnin_a.htm
john
Old Aug 28, 2010 | 08:15 AM
carnut122's Avatar
carnut122
jniolon, thanks for the timely post. Brown brought my column the other day and I hope to play with it this week-end!
Old Aug 28, 2010 | 09:39 AM
arrowheadfred
location
THANKS JNIOION YOU get it. Show the dummy pics. LOL
Old Aug 28, 2010 | 10:06 AM
AXracer's Avatar
AXracer
It's unlikely you will be able to mount it thru the firewall with any steering box I know of unless you buy one of the column offset deals some of the hot rod places sell. It's a box that mounts to the firewall with two gears in it with either a chain or cogged belt running between. One gear is the input connected to the column and the other connects to the steering box. It's a cool deal to put the column at a shallower angle more like most modern vehicles and give foot clearance for pedals etc, but not inexpensive. Otherwise it is likely to mount near to or in the stock location.
Old Aug 28, 2010 | 12:06 PM
eman92082's Avatar
eman92082
[quote=arrowheadfred;9267614]THANKS JNIOION YOU get it. /quote]
Yeah, JNIOION is a good guy. I guess the rest of us are just plain stupid because we don't get it.
Old Aug 28, 2010 | 05:27 PM
arrowheadfred
location
NO EMAN I DIDN'T MEAN IT LIKE THAT. I THANK YOU AND ALL THE OTHERS FOR THE INPUT. BELEIVE ME I NEED ALL THE ADVICE I CAN GET. WHEN IT COMES TO A MUSTANG AM ON TOP OF IT. BUT THE OLD TRUCK GAME .I'M DUM AS DIRT. YOU AND 52 ARE RIGHT AND I THANK YALL AGAIN. LIKE WAYNE SAID IN THE CARTOON HORSE BEFORE THE CART. THAT HORSE AIN'T TO SMART. I WAS TRYING TO GET IT HOOKED UP SO I COULD MOVE IT AROUND THE SHOP. I DON'T HAVE BUT ONE LEG AND THAT MAKES IT HARD TO PUSH IT. I GUESS DOING THINGS TWICE IS HARDER THEN PUSHING. COST MORE TOO. LOL
Old Aug 29, 2010 | 08:03 AM
AXracer's Avatar
AXracer
Easy on the caps lock.
Just put it in the stock location for the time being, the chances are all you may then need to do later is adjust the column drop length to suit you, your seat and the steering wheel you choose.
You never said what steering box you plan on using, or even what tilt column.
Renzen
Sep 30, 2004 07:02 AM
Jermafenser
1978 - 1996 Big Bronco
Sep 5, 2002 02:47 AM
ky renegade
17
Aug 30, 2002 11:11 AM
Franklin2
Dec 24, 2001 03:43 AM
billyb
Dec 14, 2000 07:08 PM
