dfwdiesel,
Welcome to FTE and the IDI diesel forum.
The column from a gasser F150 thru F350 should be fine.
You should be able to go several years in either direction newer or older as well.
Thanks Dave,
That greatly raises the number of potential donors, likely to include some low miles examples. Few IDE diesels wind up in the local yards.
Best Regards,
John Gregg
dfwdiesel,
Those steering colums are close to unobtainium in the local Pick and Pulls.
I took the plastic cover off the steering column and found the rod that was not
moving and pushed it by hand.
Will likely need to take the column apart to see how the connection is lost.
