Squeek under dash driving me crazy!!!
Old Jan 24, 2010 | 12:09 PM
89ford73's Avatar
89ford73
I have a wierd squeekunder dash board that I would like to fix, it sounds like baby birds chirping or something, it's only on semi-smooth to bumpy roads it stops if I press gently on the brake pedal while I'm driving. It also stops when parked. I dont think it's the loose fender problem. Help!!
Old Jan 24, 2010 | 03:42 PM
Krisx125's Avatar
Krisx125
I have the same issue!!! It sounds like the dash rubs on the windshield. And i have a crunch noise comming from the front of my drivers side of the truck. sounds like the front clip is falling off!!!! My 150 had the same noise...Hope spmeone can help! I herd soemthing about a brace under the dash that snaps and breaks..??
Old Jan 24, 2010 | 03:45 PM
Talyn's Avatar
Talyn
spring bushings?
Old Jan 24, 2010 | 04:02 PM
helifixer's Avatar
helifixer
mine has a similar noise (sounds like a dry speedometer cable) I have never found it. I know it isn't the front fenders as the front clip has been changed due to accidents.
Old Jan 24, 2010 | 04:06 PM
Krisx125's Avatar
Krisx125
And theres a loud snap that every once and a while will make the noise and its always when im driving home from work tired..And it scares the HECK out of me LOL
Old Jan 24, 2010 | 04:14 PM
Hussler's Avatar
Hussler
I have what sounds like yours (birds chirping). In my case it was the window (power) drivers side. For some reason when it happens it would go away when I rolled the window down a few inches and all the way back. Go figure, still does it. I'm just not in to tearing that panel apart this winter.
Don't discount tightening the fender bolts. I bet that is your crunch noise.
Old Jan 24, 2010 | 04:18 PM
Krisx125's Avatar
Krisx125
hmm my fender bolts are tight..however theres some kind of foam between the fender and cab, and is falling out...so i will loosen it up and fix that tomorrow.
Old Jan 24, 2010 | 04:32 PM
Hussler's Avatar
Hussler
I think it's a fiberglass insert in there, not sure though as never had to tear the fender off. Maybe someone on this site has. If you just tighten them down another 1/2 to 1 turn the issue goes away. Mine were pretty snug but did get another turn on them. I agree with what you said earlier though, scares the heck out of you. I actually pulled over a couple times to see if something broke on the suspension.
Old Jan 24, 2010 | 05:39 PM
RRranch's Avatar
RRranch
Take off your right kickpanel and see if the bolt holding the dash, next to the glove box, to the door frame is broken off. Actually the plastic bracket breaks there. It's pretty common to be broken.
Old Jan 24, 2010 | 09:45 PM
89ford73's Avatar
89ford73
ill check it out tomorrow!
Old Jan 25, 2010 | 10:03 AM
foxracing0934's Avatar
foxracing0934
I had the same problem as you, I found that if I put my fingers in the small vent slot for the defroster and push down that i can make it go away. Sometimes after it goes away it is gone but others it comes back at the next slight bump. RRanch I hope that that is my problem to becuase this sound is going to send me to the mad house lol.
Old Jan 25, 2010 | 10:12 AM
RRranch's Avatar
RRranch
Look at that bracket. It's not a hard fix and there is a Ford fixit kit out there for it even. It's easier to make your own steel bracket though. Grind off the broken plastic on the dash side, rivet or bolt a plate down the side with at least three bolts and then weld a bracket to the bottom of it that alignes with the hole on the door frame. It sounds harder than it actually is.
Old Jan 25, 2010 | 10:15 AM
Talyn's Avatar
Talyn
Yea, this is broken on mine as well.
It doesn't squeek very often anymore.
Old Jan 25, 2010 | 10:42 AM
RRranch's Avatar
RRranch
I broke mine there last fall when I was trying to chase my cows home in the neighbors pasture. We hit a little washout and got airborne. Really airborn! I don't ever want to do that again. My poor kid was in the bed swinging his rope when the tires left the ground. He ended up almost on top of the cow.
Old Jan 25, 2010 | 01:00 PM
89ford73's Avatar
89ford73
Lol funny story!
My grandpas 91 gmc don't squeak!
That stupid squeak is buzzkill hardcore too!!
steveflyswright
Jan 12, 2015 04:00 PM
James Dillis
Mar 10, 2014 03:41 PM
davidzog
Dec 13, 2012 07:04 PM
d5332
1997 - 2003 F150
Jan 27, 2011 06:30 AM
aircargoo
Feb 22, 2010 01:40 PM
