Electric Fan
Jan 25, 2010 | 05:49 PM
Jan 25, 2010 | 06:11 PM
I don't see how the math would be different for electric fans. If the same fan that is used on the engine is hooked up to an electric motor, it will take the same power to do the same work regardless of how it's powered.
The electric fans cited may work for empty trucks -- who knows. I swore they were closer to 50A though...
Jan 25, 2010 | 06:14 PM
Quote:
Originally Posted by
Izzy351
It should work for empty trucks but once you load them heavy, the equation changes. They are rated for 18K but the Ex is already 9000#, IIRC.
Jan 25, 2010 | 06:15 PM
OK, so again, why not throw an electric lockup clutch from a big rig on the fan?
-Less modding than electric.
-Same available cooling when needed.
-Maybe cheaper?
Jan 25, 2010 | 06:24 PM
parkland
-Maybe cheaper?
No reason why you could not, other then there is not one offered for our trucks, but the benifit would not out weight the cost and hassle.
The 2-3hp you might pick up is not worth the $300-$400 to install something.
Jan 25, 2010 | 06:50 PM
CSIPSD
Apparently it is, thus the 500$ electric fan set.
At least this way, you still have full cooling ability when needed.
Jan 25, 2010 | 06:53 PM
I have access to one... Its sitting out behind the shop with other stuff that doesnt work...LOL
Jan 26, 2010 | 11:06 PM
parkland
Are we sure the fan has an electronic clutch in it?
Mine feels like it has a little torque converter in it.
A clutch would be the best of both worlds, and probably an easier mod to do.
Its a viscous fluid clutch, which is similar to a t/c. Never fully unlocks or locks though. Kinda like the old c-6 trans with a non locking t/c.
Jan 27, 2010 | 04:26 AM
i think a stock fan pulls 650 CFM's witch is more then enough for our truck.. when the fan is not working (not locked up) it is not robbing HP..
scotttahoe
Feb 4, 2013 08:33 AM
F-250 restorer
Jan 20, 2011 11:25 PM
idahoturbo94
Jun 6, 2010 12:51 AM
northern 7.3
22
Jul 24, 2008 12:50 PM
arockyway2go
Jun 22, 2007 08:12 AM
73 ,
73l ,
97 ,
cooling ,
diesel ,
electric ,
f350 ,
fan ,
fans ,
ford ,
kit ,
lmc ,
powerstroke ,
review ,
truck
