Brake Issues!! NEED SOLVED ASAP!!!
Old Jan 23, 2010 | 03:39 AM
harwood39's Avatar
harwood39
ok guys, this is ergent, sort of an emergency. I am having brake issues... I am guessing it is the booster but just wanna make sure. It is on my 88 F250. And here is whats going on. Brakes work good, BUT if i hit the pedal more than once in like 30 seconds, the times after the first i have no power brakes, than they come back after about 30 sec.... SO CONFUSING Also, my booster does make a lil hiss when i push on the pedal, and i know that is not right. Is there anythign else that can cause this? Need fixed ASAP as this is my plow truck and we have 6 inches of snow coming....
Thanks!!
Old Jan 23, 2010 | 04:18 AM
Lazy K's Avatar
Lazy K
One of two things, either you have a vacuum leak (like a bad booster) or the vacuum pump is bad or the drive belt is bad.
If you pull the vacuum pipe off the booster and with engine running put the palm of your hand on the end of the pipe. If the vacuum pump is good it should feel like it wants to suck your hand into the pipe.
If you have a vacuum gauge it should show around 20in of vacuum.
Old Jan 23, 2010 | 04:30 AM
harwood39's Avatar
harwood39
booster and master cyl look newer. and i believe they were replaced when i bought the truck, cant be positive on that. i will check the pump. This sucks cause we are getting freezing rain! and the truck doesnt fit in the garage... I would much rather replace the booster than vacuum pump tho... Its about half the price and just a little bit easier to get to...
Old Jan 23, 2010 | 04:42 AM
harwood39's Avatar
harwood39
ok, so it is the pump.... not too excited to replace this... i know i gotta use a pulley puller to get it done... i just really dont wanna do this in the 36 degree weather and rain...
I did the vacuum tests, and sure enough, low vacuum...
So any tips to get it in and out quickly would be much appreciated
Old Jan 23, 2010 | 04:48 AM
Lazy K's Avatar
Lazy K
Do a search here for "vacuum pump" there should be lots of info on fitting one.
Had to replace a rad a couple of years ago in similar conditions so i don`t envy you.
Good luck.
Old Jan 23, 2010 | 04:51 AM
harwood39's Avatar
harwood39
all i can say, even tho its wet and cold, atleast its not 30 below... haha. if that was the case, i would take it to a local diesel shop that my other truck is at right now and just borrow the shop for a couple hours...
Old Jan 23, 2010 | 04:53 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...placement.html Turned this up in a search. Have a read.
Old Jan 23, 2010 | 05:10 AM
tjc transport's Avatar
tjc transport
i ain't rite
when i do vacuum pumps, i just spend the $22 and get a new pulley from the dealer.
less headaches trying to get the old pulley off and back on.
Old Jan 23, 2010 | 05:12 AM
harwood39's Avatar
harwood39
thanks, my only question, is on these older trucks do we need to pull the pulley before removing the pump??
Old Jan 23, 2010 | 05:24 AM
tjc transport
i ain't rite
on the 6 88 to 91 7.3 trucks i had, no.
Old Jan 23, 2010 | 05:30 AM
harwood39's Avatar
harwood39
Well it looks like im off to the parts store in 2 hours when they open... Another $110 bucks into this truck... the last 3 weeks has been hell on my pocket book and trucks... Water pump just went on this thing too, wish the vac pump would have gone at the same time.
Old Jan 23, 2010 | 09:40 AM
starmilt's Avatar
starmilt
It only takes about 10 minutes to get off, a lio of dealers have to order the pulley.
Most parts houses will pull and install your pulley for 5 bucks or left.
Old Jan 23, 2010 | 05:49 PM
wreckinball's Avatar
wreckinball
yeah snag a machinist or shop, they will do it for pennies, it takes them no time to knock it out!
Old Jan 24, 2010 | 03:54 PM
harwood39's Avatar
harwood39
I got the pump from orielys, and had the ford dealer swap pulleys, i actually removed the old pump in the parking lot, brought both in, said, ok, i need this pulley on the new pump, the tech asked why i didnt just bring the truck, and he just laughed when i told him its in the parking lot and i did the work out there. He swapped the pulley for free.
Old Jan 24, 2010 | 07:13 PM
Popeye2347's Avatar
Popeye2347
Good for you! Keep warm and be careful pushing all that snow, just bring home the $$$.
Cambiocorsa
Oct 15, 2010 08:42 AM
MY68F250
25
Apr 7, 2008 08:29 PM
amiele
Escape & Escape Hybrid
Nov 17, 2006 09:37 PM
hoxiii
Dec 24, 2004 12:53 PM
krock22
Sep 21, 2004 09:35 AM
