Vacuum Pump Replacement
Old Dec 2, 2009 | 06:49 PM
allerickb's Avatar
allerickb
I'm in desperate need of getting my vacuum pump replaced, but I can't get the pulley off the pump to remove the bolts. Any ideas on what it takes to remove it? I'm currently getting maybe one good pump of the brakes before the lack of vacuum renders my brake booster useless. Thanks
Old Dec 2, 2009 | 06:56 PM
starmilt's Avatar
starmilt
What year model. The older ones had 3 bolts holding the pulley on.
Old Dec 2, 2009 | 07:00 PM
branden.w's Avatar
branden.w
i couldnt get off either, i took it to a shop and they did it for five bucks
Old Dec 2, 2009 | 07:43 PM
starmilt's Avatar
starmilt
lol Something just ain't right here where is that shop located.
Old Dec 2, 2009 | 08:03 PM
allerickb's Avatar
allerickb
Its a '94. It too had 3 bolts, but after backing them most of the way you back right into the pulley. I had read in previous post that you need a certain type of puller to get it off without damaging it.
Old Dec 2, 2009 | 08:15 PM
starmilt's Avatar
starmilt
Ok that is a whole different setup the older ones was EASY. I have never had to change that style probably need something like a power steering pump puller.
Some parts houses rent them.
Old Dec 2, 2009 | 08:56 PM
87crewdually's Avatar
87crewdually
You need a power steering pump pulley puller. Some part houses will let you change it there or rent the tool to you. Or go buy one from a discount place like Harbor Frieght. This is a power steering pump but same pricipal.
http://www.harborfreight.com/cpi/cta...emnumber=66868
Here's a link for another style. To install just use a long bolt with a nut and washer to push it back on the new pump.
Old Dec 2, 2009 | 11:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
And any other way will damage the pulley.
Old Dec 2, 2009 | 11:41 PM
wreckinball's Avatar
wreckinball
I am soooo glad i have the older style. man what a drag! Luckily most of the shops will do it for cheap!
branden.w's Avatar
branden.w
greenville, ca indian valley trading post, i had it out already and just handed him the pump. it took him two minutes but i didnt see what he used, i tried using a pully puller and it started to bend it so i just took it in.
Old Dec 3, 2009 | 01:00 AM
starmilt's Avatar
starmilt
Branden go back and read your post again thats why I wanted to know where the shop was. I have a power steering puller and installer.
Old Dec 3, 2009 | 01:32 AM
branden.w's Avatar
branden.w
starmilt... yea i went to take it off with a pulley puller and the sides started bending in, so i had to even it out and it is now off center and wobbles a bit. so i just took it in. do you live in cali?
Old Dec 3, 2009 | 01:50 AM
starmilt's Avatar
starmilt
This is the post read it real close.
Old Dec 3, 2009 | 01:52 AM
starmilt's Avatar
starmilt
Noooooo on the cali, I'm in fairbanks.
Old Dec 3, 2009 | 02:09 AM
branden.w's Avatar
branden.w
lol, your minds in the gutter. im moving to alaska in august. how do you like it there?
