c6 transmission
Old Jan 22, 2010 | 07:36 PM
tbenks's Avatar
tbenks
c6 transmission
just to double check in an 1987 c6 auto tranny would you run type F or mercon fluid? thanks
Old Jan 22, 2010 | 08:01 PM
Hitokori's Avatar
Hitokori
ATF Dexron/MerconIII
Old Jan 22, 2010 | 08:11 PM
tbenks's Avatar
tbenks
ok, so lets say some "idiot" decided to run type F instead, how bad would this be for said "idiot"?
Old Jan 22, 2010 | 08:50 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
Im not 100% but I think the Type F has a friction additive and .... I think it is very bad for some poor " person " I kind of hope for there sake I'm wrong.
Old Jan 22, 2010 | 09:12 PM
JEAkridge's Avatar
JEAkridge
id be droppin the pan, draining the converter, and changin filter. drive for a week and repeat.
Old Jan 22, 2010 | 09:24 PM
tbenks's Avatar
tbenks
can you expand on this please?
Old Jan 22, 2010 | 10:03 PM
JEAkridge's Avatar
JEAkridge
ford placed small drain plugs on the engine side of some torque converters. may '86 bronco had a c6 and had one
Old Jan 22, 2010 | 10:12 PM
JEAkridge's Avatar
JEAkridge
Ford C6/NP205 removal and re-installation guide .: Articles this may help just copy and paste in browser
Old Jan 22, 2010 | 10:22 PM
tbenks's Avatar
tbenks
can you expect to get all of the fluid out with draining the converter and taking off the pan?
Old Jan 22, 2010 | 10:54 PM
JEAkridge's Avatar
JEAkridge
no, if you have a trans cooler there will be old fluid in it unless you drain your lines out. then there will only be a small amount left but not enough to harm
sedly
Feb 3, 2009 12:35 PM
countryboy29
1978 - 1996 Big Bronco
Oct 2, 2002 08:11 PM
comet
Sep 1, 2002 10:00 PM
f150sleeper
May 26, 2001 10:39 PM
fordmando
Apr 2, 2001 09:31 PM
