C6 trans vac. modulator
Old Jan 19, 2010 | 12:07 PM
82ford302's Avatar
82ford302
long story short when i swapped in a new cam and fixed the broken vacuum tree on my intake, it seems now the vacuum modulator on the transmission does not work. before i did all the repairs it shifted fine with no problem. now i have to manually shift it in order to change gears. i hooked the modulator vacuum line back where it was on the vacuum tree on the 390 intake. i replaced all the vacuum lines with new rubber so it isnt leaking anywhere. could my modulator just of went bad just like that? the truck was only down for 3 days.
thanks
Old Jan 19, 2010 | 12:17 PM
jk080's Avatar
jk080
Transmission Rebuilder
Check the vacuum at the modulator it should have about 15 to 20 inches of vacuum at idle.
Old Jan 19, 2010 | 12:25 PM
Lazy K's Avatar
Lazy K
It sounds like you have no vacuum at the modulator or the modulator is bad or the line to the modulator is bad.
With engine at idle get under and pull the vacuum pipe off the modulator at the trans. There should be a noticable change in engine note. If no change put your finger over the end of the rubber pipe and listen for a change in note and you should feel a strong vacuum. If there is a change in engine note then and you do feel a vacuum then the modulator is bad.
If still no change and no vacuum then plug pipe back on and investigate why there is no manifold vacuum connected to the pipe at the engine end.
Old Jan 19, 2010 | 12:29 PM
82ford302's Avatar
82ford302
dont have a guage, but when i pulled the vacuum line off the modulator it doesnt have any vacuum to it when i put my finger over the end. so im asuming that the vac. tree on the intake doesnt work. the only other ported vacuum source i have is 1 port on the carb that my distributor vac. advance is hooked too. could i run it off that to make sure it works on that port?
Old Jan 19, 2010 | 12:35 PM
Lazy K's Avatar
Lazy K
Don`t see why not.
jk080's Avatar
jk080
It needs to be manifold vacuum, ported vacuum wont work the modulator correctly.
The vacuum needs to drop when you press the accelerator.
Old Jan 19, 2010 | 12:38 PM
82ford302's Avatar
82ford302
ok i see. could i install a T-fitting on the back of my carb spacer since it ties with the brake booster line?
Old Jan 19, 2010 | 12:45 PM
jk080's Avatar
jk080
I have never installed it there, as long as it has vacuum at a idle and drops during acceleration it should work. Try it you can always undo it.
Old Jan 19, 2010 | 12:47 PM
82ford302's Avatar
82ford302
ok thanks i'll give a shot. worse case it dont work lol.
Old Jan 19, 2010 | 01:28 PM
82ford302's Avatar
82ford302
just got back from the drive. shifts like its supposed to. thanks for the help guys
Old Jan 20, 2010 | 04:44 AM
Lazy K's Avatar
Lazy K
The dist. port is below the throttle butterfly so should meet those conditions. However it is small and so modulator response may be slow, not sure.
Redneckfordf2502002
Feb 26, 2014 04:09 PM
78 & 87 Super Cab
Nov 7, 2013 12:44 PM
Alan17
Oct 13, 2013 04:07 PM
-Ross-
Sep 20, 2013 03:33 PM
berry1234
Mar 23, 2010 12:28 PM
