Rattle when accelerating
Old Jan 19, 2010 | 12:24 AM
Ducky015's Avatar
Ducky015
i own a 2002 lincoln navigator 4wd.
today when i was driving it i noticed a rattle noise coming from the under the center console of the front....
i wana guess its the heat shield clamps.. but i dont want to be wrong
plz help!!!!
Old Jan 19, 2010 | 07:31 AM
fordtech08's Avatar
fordtech08
well first is it coming from under the center console or coming from under the truck?
what do you have to do to make it happen
Old Jan 19, 2010 | 07:36 AM
Ducky015's Avatar
Ducky015
its under the truck but the sound is come from around the center console area of the car.
All i have to do to make the sound happen is accelerate i hear a rattle noise.
Old Jan 19, 2010 | 07:44 AM
fordtech08's Avatar
fordtech08
does it do it in reverse and drive? you can crawl under the truck with it running and listen to the converters one of the shields could be coming loose or it could be the converter coming apart, look for signs of damage like you hit something, or if you want to just guess go to a part store and get a worm clamp that is about a foot throw it on the passenger side converter ( that is why it sounds like the center)
also it could be a trans problem
Old Jan 19, 2010 | 07:48 AM
Ducky015's Avatar
Ducky015
i only heard it most when i drove, but ill check today if it does it in reverse also. there isnt a problem when the car is in idle, only when i accelerate and cruising around. okay ill post about what happens when i check the converters.
Old Jan 19, 2010 | 07:50 AM
fordtech08's Avatar
fordtech08
also is it at a certain speed or just anytime you accel
Old Jan 19, 2010 | 08:02 AM
Ducky015's Avatar
Ducky015
just anytime i pushed the accelerator. and i also remember when i put it in neutrual and revved the engine there was no rattle..
Richwon4
Aug 13, 2016 05:48 AM
tennesseex
Jun 30, 2016 12:24 PM
hermannm2
2009 - 2014 F150
May 25, 2016 08:45 PM
Silver4bye
Jul 5, 2005 01:20 PM
COACHBRITT
Dec 15, 2004 02:09 PM
