Rattle on Acceleration
Old May 24, 2016 | 05:43 PM
hermannm2's Avatar
hermannm2
Hi,
I have an occasional slight rattle when I am accelerating. Sounds like it is coming from the driver wheel well. If i let off the gas or shift into a lower gear the rattle seems to go away.
Truck is a 2011 F-150 5.0.
Thanks,
Old May 25, 2016 | 01:08 PM
meborder's Avatar
meborder
is it 4wd?
if so check the vacuum check valve for the front hubs.
fairly common problem.
Old May 25, 2016 | 01:15 PM
Jco06's Avatar
Jco06
Check your skid plates and heat shields on your exhaust. I had a heat shield make a horrible noise during acceleration.
Old May 25, 2016 | 02:30 PM
hermannm2's Avatar
hermannm2
Yes it is a 4 wheel drive. I used to hear stories about the cam chain tensioner, but I searched the forums and couldn't find any posts.
Where is the check valve located?
Originally Posted by meborder
is it 4wd?
Old May 25, 2016 | 08:45 PM
meborder's Avatar
meborder
See if this helps:
https://www.ford-trucks.com/forums/1...iver-side.html
Ckasten99
2009 - 2014 F150
Sep 19, 2018 10:14 AM
codfish
2009 - 2014 F150
Sep 16, 2015 02:33 AM
TheMech
Dec 1, 2009 03:03 AM
fyrmnk1
Nov 14, 2009 02:18 PM
trx450ripper
1997 - 2003 F150
Oct 29, 2008 07:39 PM
