Shudder???
Old Nov 15, 2009 | 07:46 AM
swflbronco's Avatar
swflbronco
Shudder???
Hi guys, I have researched this problem in the forums but mine seems to be different, that said on my 03 Expy when going to pass someone or merge into traffic there is a SHUDDER but only at that time. I have not felt this when going slow and turning the mileage is 128k the truck has had all the major services done to it, just curious if this a BIG problem.
Old Nov 15, 2009 | 08:59 AM
madsonp's Avatar
madsonp
Does it feel like it's something in the drive train, or in the steering/suspension ?
Old Nov 15, 2009 | 11:58 AM
swflbronco's Avatar
swflbronco
It feels like the drive-train, thought it may be the LSD or the Torque converter. I only notice it when I step on the gas to downshift to pass or merge?
Old Nov 15, 2009 | 12:35 PM
madsonp's Avatar
madsonp
When's the last time you changed your tranny fluid ?
Old Nov 15, 2009 | 12:47 PM
alloro's Avatar
alloro
It sounds either like one of the COPs is misfiring, or the fuel pump is having trouble supplying enough fuel, under heavy load.
Old Nov 15, 2009 | 01:01 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
Just trying to help narrow down possibilities here... You could get a shudder from the torque convertor but only if it was locked up, or trying to lock up. Typically under heavy acceleration the TC is unlocked and you are not going to get any type of shudder out of it.
The LSD will not give you a shudder unless you are engaging the clutch packs, either because you are going around a corner under power or one of the wheels is starting to slip. Accelerating down a dry on ramp isn't likely to cause an LSD type shudder.
Old Nov 15, 2009 | 07:23 PM
swflbronco's Avatar
swflbronco
Just had all of the COP and plugs done 8k miles ago,as for the tranny I will have to check my file. My thoughts on the LSD were the same but thought the torque converter may be giving up the ghost just like tha A/C blower motor did, was working one day then nothing the next.
Old Nov 16, 2009 | 09:11 AM
alloro's Avatar
alloro
Irrelevant, good/new parts fail all the time. This is still something to consider and check out.
Old Dec 6, 2009 | 08:37 AM
swflbronco's Avatar
swflbronco
Just a little update....found out that it only does this in OD....take it out of OD and there is no shudder when stepping on the gas. Is it possible for the OD part of the trans to be the issue and will it need a complete rebuild???
Old Dec 6, 2009 | 09:00 AM
Big Greenie
Before going off the deep end and thinking you need a trans rebuild, how about just servicing it first? These transmissions are pretty sturdy, and unless it has been abused badly it should be a long way from needing a rebuild.
Old Dec 6, 2009 | 11:54 AM
pdqford's Avatar
pdqford
Ditto.
Old Dec 6, 2009 | 07:40 PM
swflbronco's Avatar
swflbronco
Thanks guys this will be my course of action in the beginning of the week, should I take it to a trans shop or the shop that I have the oil changed at? Also is the service for this fluid and filter?
Old Dec 6, 2009 | 11:57 PM
madsonp's Avatar
madsonp
Yes, fluid and filter. I'd say you're better off taking it to a tranny shop. Make sure they do a complete flush.
Old Dec 7, 2009 | 07:04 AM
Big Greenie
I agree, find a reputable trans shop, have the fluid flushed and filter changed. I would also discuss the problem you are having with a trans expert. They are likely to have more insight than us.
Old Dec 7, 2009 | 09:15 AM
benningstspeed1.0's Avatar
benningstspeed1.0
THE 4R75 IS KNOW TO HAVE A LITTLE SHUTTER. I HAVE AN 07 F150 THAT HAD A MILD SHUTTER UNDER LIGHT TO MID ACCEL FORM DAY ONE. MOST TRANYS HAVE SOME WORSE THAN OTHERS. TRANS SHOULD BE SERVICES EVERY 30K. WE HAVE MANY CARS AND TRUCKS COME IN THE SHOP WITH SHUTTERS. WE JUST SERVICE THE TRANS AND MOST LEAVE JUST FINE.
