ICP 2003 6.0 Location
Old Jan 18, 2010 | 12:31 AM
donaldblanton's Avatar
donaldblanton
I am currently trying to change the ICP sensor and as all the rest i have been reading it looks to be the problem. But on my 03 F350 4x4 6.0 Diesel is this sensor on the back of motor, next to firewall? I FINALLY got the turbo off and I think i found it but its still behind a load of crap and I wanna make sure its it before I do anymore removing things. thanks.
Old Jan 18, 2010 | 07:50 AM
l-m tech's Avatar
l-m tech
its the one closes to the fire wall.it has a 3 wire connector
Old Jan 18, 2010 | 08:10 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
This thread (from the Tech Folder sticky at the top of this forum) will show you exactly where it is and how to change it out:
https://www.ford-trucks.com/forums/8...ml#post7693493
Old Jan 18, 2010 | 08:53 AM
donaldblanton
thanks for the help
Old Jan 18, 2010 | 08:58 AM
rocky1074's Avatar
rocky1074
I purchased a 1 1/16 deep 3/8 drive socket. Got the new icp sensor and cut the socket down to size. Used a 3/8 swivel and a 6" extension. It still was a job to get it out from the top. I tried from under but my arms were to short to reach up there. I guess the best way is on a lift is available. I also removed the FICM for more room to work.. Good Luck
Old Jan 18, 2010 | 09:09 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE donaldblanton I see the guys have you up to speed.
Old Jan 18, 2010 | 08:45 PM
donaldblanton
yes they did and thanks. I got the ICP changed and how i got a new problem. The Idleing bad and all stopped so i know that fixed that problem, now to the new one.
I think the Clamp that hooks the exhaust up to the turbo (the intake exhaust not the exhaust out to the muffler) and i can hear something blow air once the little selonoid valve opens on the turbo calling to recirculate the air back through (think its called a dump valve not sure though) Anyways when i drive it theres no power at high RPM's like it should have. Plus i can hold the pedal to the floor and it won't rev above about 2700 RPM it starts sputtering. I guess what i am trying to ask is will this loose clamp cause that. If so would it be benificial to go to dealership and get a new metal clamp?
patino1
Mar 1, 2025 07:41 PM
chadjones99
Jan 31, 2015 07:31 PM
USMCveteran
Nov 18, 2013 12:22 AM
dvldog13
Aug 6, 2013 12:24 PM
Attilak1
Jul 31, 2010 03:36 PM
