Sponsored by: Real Truck
ICP delete
Old Jan 31, 2015 | 06:01 PM
chadjones99's Avatar
chadjones99
ICP delete
Has anyone done a ICP sensor delete. I ask this because I have a 03 6.0L
and the ICP sensor is on the back of the motor where you cant reach it and about every 3 years I blow out my ICP sensor and its always when we are out of town and leaves me on the side of the road. I know it has a purpose to protect the engine on low oil ,but I have never been low on oil ( with out the ICP failing ) , but I have been stuck on the side of the road because my ICP blow out cause oil to blow out everywhere leaving me stranded .
Just wondering if anyone else has thought about doing a delete on the ICP and bypassing the wires to trick the sensor ?
Old Jan 31, 2015 | 06:08 PM
Unrealo4's Avatar
Unrealo4
It actually tells your computer how much pressure is in the high pressure oil system. Thats used to determine how your fuel system is behaving. There is no delete for the icp. Your truck needs it! Thats why your stranded when it fails.
Old Jan 31, 2015 | 07:20 PM
chadjones99
ICP
Can it be relocated. when it fails I can not reach it.
Old Jan 31, 2015 | 07:31 PM
Unrealo4's Avatar
Unrealo4
Theres a topic in the 6.0 forum about it. You could have a custom hydraulic hose made with the correct fittings on each end. But it seems like if its longer then 12 inchs it doesn't work properly. Also it would have to be protected from all the heat of the turbo.
NauticaEE
Nov 12, 2011 04:10 PM
just another truck
Jul 21, 2011 07:13 AM
new2diesel
Apr 3, 2011 05:04 PM
Ken_C
Feb 16, 2011 07:38 PM
brad7.3
Aug 20, 2006 09:37 PM
