How to do the bb mod
Old Jan 16, 2010 | 04:22 PM
PorchFarms's Avatar
PorchFarms
This is how i performed the bb mod on my truck. This mod is to boost fuel pressure up from 55 to about 75. First i removed thermostat housing by removing using a 10 mm. I then pushed the thermostat housing to the front to give me room to remove fuel pressure regulator. Then remove the line on the fpr. The bolts on the fpr are a t27 torx. Remove all four bolts holding it to the upper fuel filter. Watch out because the spring has it under pressure. Make sure the spring and brass poppet valve doesnt fall out. Take a .177 bb and slide it in the brass poppet and reassemble everything. You will lose some coolant doing this mod so make sure you have some on hand. Some companies sell a longer spring but the bb is cheaper.
Old Jan 16, 2010 | 04:35 PM
foul1's Avatar
foul1
Im stupid Why?
Old Jan 16, 2010 | 04:44 PM
Fandini's Avatar
Fandini
Originally Posted by foul1
Im stupid Why?
Ditto, fill me in!
Old Jan 16, 2010 | 04:56 PM
PorchFarms's Avatar
PorchFarms
The reason is to make sure the injectors are never starved for fuel. I have heard of fuel pressure dropping to 35 at WOT. Doing this mod should keep the fuel pressure at 55 at WOT.
cartmanea's Avatar
cartmanea
Its better for the injectors, but it won't raise from 55 to 75. I did the mod because my idle fuel pressure was only 53 and dropped to 44 at WOT, after the BB mod it idles at 62 and drops to just 55psi. 8-10 psi increase is standard.
Old Jan 16, 2010 | 06:19 PM
Fandini's Avatar
Fandini
Isn't that harder on the fuel pump? Seems to me it would make the fuel pump work harder and therefore shorten its life. The more I tinker the more I seem to find that not much seems to improve any OEM settings if you are using it as it was intended. Just my thoughts. So, would that not be harder on the fuel pump?
Old Jan 16, 2010 | 06:25 PM
bismic's Avatar
bismic
The pump does not work any harder. The BB is in the regulator that returns fuel to the pump suction. With the BB in the spring, it reduces the fuel return, thus elevating the fuel pressure to the injectors (the pump discharge pressure is not affected much at all).
Old Jan 16, 2010 | 06:39 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Wow, who thinks of stuff like this? I might have to attempt this, when it gets warmer outside! Bismic, would you say this is a good mod to do?
Old Jan 16, 2010 | 07:40 PM
bismic's Avatar
bismic
I am either doing this mod or buying an upgraded spring.
I didn't really describe it well in the previous post. The BB isn't acting like a restriction (which is how it sounded after I re-read my previous post), but it is (in effect) making the spring stiffer and thus requiring a higher pressure for the fuel to recycle back.
Cheezit stated that it might be adviseable to get a replacement fuel regulator kit since some internal parts can experience some wear (the plunger). The replacement regulator kit should also come with a stiffer spring. For me, I only have 60k miles, so I do not think I need the replacement regulator kit yet.
Old Jan 16, 2010 | 07:48 PM
rickatic's Avatar
rickatic
Looks like another easy reliability mod to do as I install my new engine
Old Jan 16, 2010 | 08:05 PM
cartmanea's Avatar
cartmanea
Actually, it does make the pump work harder, but I'd rather the pump work harder than the injector feed drop below 45 psi. If you look at pump flow charts, higher pressure creates more current draw for the same flow rate.
Old Jan 16, 2010 | 08:19 PM
bismic's Avatar
bismic
Your fuel pressure is first regulated to 100 psig out of the HFCM, so your pump is really not increasing its pressure based on what is happening at the fuel filter regulator. The fuel pressure is first regulated at the HFCM and then further regulated by this spring loaded regulator at the fuel filter to the 45-65 psig we see with our gauges.
Old Jan 16, 2010 | 08:23 PM
bismic's Avatar
bismic
Here is a pic of the fuel line tie-in where the regulator is:
https://www.ford-trucks.com/forums/p...ictureid=24055
The fuel pressure regulator kit number (if you would want to go that route) is either:
4c4z-9t517-aa
or
3C3Z-9T517-AE
There are two kits one is a reseal kit and one is a complete kit with the housing.
A Tech told me that the one he installs is 3C3Z-9T517-AE it should be the complete kit. It is the same from 03 to 07.
Because of his input, I am not sure what is included in the 4c4z-9t517-aa part.
Old Jan 16, 2010 | 08:32 PM
mojo1's Avatar
mojo1
Will this mod make the truck perform any way differant or is it just better on the injectors ?
Old Jan 16, 2010 | 08:39 PM
bismic's Avatar
bismic
It is only to protect the injectors
