Radiator Replacement
Old Jan 14, 2010 | 12:29 PM
LKWDF350's Avatar
LKWDF350
I have 99 expy 4x4 5.4 eng. w/110k miles that is leaking coolant from the lower left corner of the radiator. I also see a small leak coming from the top left corner through the cooling shrowd. I am replacing the radiator. I was thinking of replacing the hoses as well. Is this a small job that can be tackled at home?
Old Jan 14, 2010 | 12:44 PM
alloro's Avatar
alloro
Yes, just allow yourself about 3 hours to do it. Probably the biggest issue you'll have is disconnecting the lower radiator hose. There's a metal tab that has to be bent back, then the hose gets twisted 45 degrees, then you pull it off. Pulling it off is easier said than done. I have found that removing the wheel well skirt from inside the driver's wheel helps a lot.
BTW, Radiator, Radiators: RadiatorExpress.com. Car radiators, auto radiators, radiator replacements, Radiator Express is usually the cheapest place to get a radiator and they deliver.
Old Jan 14, 2010 | 09:59 PM
dirtmonkey11's Avatar
dirtmonkey11
The job itself is not that bad, it just takes some time. Like "alloro" said, if you take of the inner wheel well skirt will save you tons of time and headaches. Also when your doing the job replace any clamps that aren’t up to par.
521scjbbf
Jan 28, 2017 12:40 PM
Laner
6.4L Power Stroke Diesel
20
Jul 7, 2014 09:14 PM
Mhintlian
Mar 26, 2014 03:56 PM
1978f-250
Jan 10, 2014 03:11 PM
Corter
47
Feb 28, 2013 05:29 PM
