Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- Radiator Reviews
Reviews and comparisons of top products
Dealer want $2,200 to replace my radiator
Over the past few weeks I have noticed small drip of antifreeze on the driveway, so I dropped the truck off at the dealer to see if it might be covered by the tsb that I have read about on the forum.
The truck is a 2008 F250 6.4 with 52,000 miles. I got a call back from the dealer this afternoon to tell me it does have a very small leak on the right side of the radiator and it's not covered and they need $2,200 to replace. After looking over the quote, no wonder it's that much. They want to replace everything on the cooling system (radiator, overflow tank, both rad hoses, thermostat, etc) with a charge of 5.5 hours of labor @ $110 an hour.
Is it just me, or does this seem a little excessive? Do I really need to replace everything or just the radiator.
ROFL, got a good laugh when I read everything the TSB states to replace but then they refuse to cover it under warranty. All comes down to where the leak actually is as to what is covered and what isn't. I was denied because they claim it leaked at the split point on the lower hose and only replaced the upper and lower hoses. If it leaks on the ends it gets coded to the 5/100K warranty. If the actual radiator is leaking I can't remember the coverage, too many things have changed over and over to remember what is current.
If I choose to use an Indy shop in town that will do it for less, I still have my $250 fee from the Stealer (I mean dealer).
Just my two cents, Ford covered my first 2 radiators and wanted 1500 for the 3rd because it's no longer under warranty. The dealership claimed my tuner caused the leak. Ummm what about the other two?? Anyway get an aftermarket radiator I did hope that solves the problem. Seriously Ford crimped on plastic end caps with an aluminum core... and it's more than 600 bucks... Just the radiator man nothing else is needed. It absolutely KILLS me Ford is aware of the issue but does nothing and will install a radiator of the same quality that failed !!!
Don't get me wrong, I have a lot of respect for a factory tech. My dad ran a BMW shop to ten years. I have a problem with the way they are figuring the labor. I think they are charging the labor piece by piece. Example...they want .5 hours for the radiator hose replacement, but you have to pull them to change the radiator. And three hours for the thermostat seems a little excessive.
I'm not diesel mechanic, but I have restored three frame off hotrods. I think they can cut the labor in half.
I was told it didn't matter where it was leaking or what caused it, it wasn't covered under warranty unless it fell under the 3yr/36,000. Where they got me was the $250 diag fee. They did tell me that I can transfer the diag fee toward the repair if I choose to use the dealer.
I just got my 1st radiator installed a couple of weeks ago.The dealership installed radiator and new overflow tank as per TSB and Ford warrantied it.Don't know how they coded it but Ford covered it.I have paid for upper hose and was losing small amount of coolant every few months and they couldn't locate leak.Finally found leak on top LH corner of radiator.Mabe because they had tried to find coolant loss since before 36000.Have drove 1500 miles and no coolant loss in overflow bottle.
My cost on an aftermarket radiator from O'reillys is $760. The delear wants $850 for an OEM replacement. Not sure if the O'reillys replacement is any better. If I can get the $65 an hour indy shop to do the repair, it would save me half the labor as the dealer is $110 an hour.
Another option is to ask around and see if any diesel mechanics in your area do any moonlighting on the side.
It definitely sounds like they're milking it. Go the independent shop route. Like you said....dealership mechanics do good work (at least from what I've experienced). However, they don't do anything that you can't get for less $$$ from an independent shop.
I had a local Ford Diesel tech that would do some moonlighting for cash money, but he has recently stopped. Heard the dealer caught wind of his practice.
