Leaking Radiator
Old Mar 24, 2014 | 10:05 PM
Mhintlian's Avatar
Mhintlian
Leaking Radiator
1989 F-250 4wd 5.8 litre/351. My radiator is leaking slightly on the left side/passenger side. Curious to know rebuild i.e. replace the gasket between the tank and core or replace? If so then should I replace the gasket on both sides or replace the whole radiator ? Radiator started to leak after flushing cooling system and replacing radiator cap. Advise.
Matt Hintlian
mhintlian@yahoo.com
Old Mar 24, 2014 | 10:58 PM
OldGrayFord's Avatar
OldGrayFord
I would replace it. It's old and would likely have more problems down the road
Old Mar 26, 2014 | 03:36 PM
Mhintlian's Avatar
Mhintlian
Thank you for your comment. It is truly appreciated.
Matt Hintlian
Old Mar 26, 2014 | 03:56 PM
OldGrayFord
I replaced mine with an all aluminum replacement fro Summit Racing. I've been very happy with it. The quality is good and it fit perfectly. Others on this site have pointed out that Summit was a little more expensive. I believe Rock Auto and eBay were both mentioned as cheaper alternatives. Best of luck, I would consider replacing the thermostat and hoses while your at it.
krustiy lusti
18
Apr 9, 2017 07:22 PM
BigBlue2
Oct 23, 2016 08:22 PM
daltonruff
1997 - 2003 F150
Apr 11, 2013 10:00 PM
jadmt
Dec 17, 2008 07:04 PM
beast51
1997 - 2003 F150
May 9, 2008 05:05 PM
