I got my vent window frames and posts back from powder coat; now need to rivet hardware into position.
Did those of you that restored these pieces use pop rivets or split rivets ? I guess the concern with pot rivets is whether they will possibly leave too much material for the proper glass and rubber seal clearance.
Also, does anyone with 48 or 49 F1 have picture of what the stock red pin stripe on window frame looks like ?
I get most of my rivets from aircraft suppliers. They actaully tend to be the least expensive. Try wicksaircraft.com or aircraftspruce.com. They should have what you need.
McMaster is the place to go not so much because they have everything known to mankind, but their catalog has extremely detailed descriptions of each item and includes tutorial-like discussions of the different materials and coatings and their applications. With even a little understanding of the job (which you have), McMaster supplies the rest of the info you need to get exactly the right item.
Excellent news. It might not have been McMaster-Carr, but there was some company that I've suggested several times that had some kind of shipping issue with Canada (which just seemed weird to me)
I hate it when the rectal-cranial inversion kicks in and I can't remember things
I used pop rivets on mine, the hand squeeze kind, with the gun, and it worked great. I would run out to the garage and tell you what size I used but I'm at work, so that will a have to wait until I get home tonight. But I can tell you none of my local parts stores carried the right size. They had the right diameter but not the right length, everything was too long. So used a grinder, to grind down each one before popping them into place. Another thing to mention was the gun. I had to force the tip of the gun into the channel, in a couple of areas. Rubbed the felt off, only about an 1/8in, not enough to be an issue. But if you were to take your time I'm sure you could avoid this problem. Other then that, pop rivets worked great, much easier then taking everything apart to use the hammer in kind.
I think you're talking about the main window channel; the OP was about the vent window hinge rivets?
