POP rivets
Old Feb 17, 2009 | 09:46 PM
pintoches's Avatar
pintoches
POP rivets
Some one before me made a metal frame on the back sliding window to seal the camper to the cab. After I remove the pop rivets there will be small holes.
How and with what should I seal them with?
Old Feb 17, 2009 | 09:53 PM
Chaosracing's Avatar
Chaosracing
If you have a welder, plug weld them shut. If not then grind paint away from all holes, use a body hammer and tap the hole in slightly so there is a small dent there and fill in with body filler. Sand filler, prime, use spot putty, sand down, reprime, sand and paint
Spktyr
Mar 17, 2013 12:46 AM
tip49
13
Jan 15, 2010 05:27 PM
Aztrainer
Jul 29, 2004 01:46 PM
DFB2004
Oct 16, 2002 05:32 PM
jethro
Mar 28, 2001 10:16 PM
