Sponsored by: Auxito
brake caliper problem
Old Jan 13, 2010 | 06:24 PM
mikersix's Avatar
mikersix
I replaced the rotor and pads on my 2000 expedition but now i am having a problem replacing the 2 t45 bolt through the caliper into the caliper bracket. i can get the top one in ok but the holes on the bottom are not lining up. the caliper is riding about 1/8 of an inch too high to line up. anyone run into this problem?
Old Jan 13, 2010 | 08:30 PM
steve(ill)'s Avatar
steve(ill)
i would take the caliper back off and measure the hole center line to center line and compare to the old caliper. Maybe they sold you the wrong one? Maybe it was made wrong? Maybe the bolt is cross threaded and not straight, i hope not.
Old Jan 13, 2010 | 09:01 PM
moto57's Avatar
moto57
Well seeing how you only replaced the rotor and pads....the existing caliper and caliper mount are still the same. So the only things that may be the problems....
1) Anti Rattle clips not fully seated
2) The rubber boots for your slide pins have a attached washer with 2 flats sides for indexing(keeps the boots from spinning?) my guess is the flat side isnt where it should be? If the flat side isnt where it should be the second pin wouldnt fit in the hole.
simulatedjim
Aug 9, 2014 07:51 PM
JNewren
2009 - 2014 F150
Aug 3, 2014 01:17 PM
Old and Busted
Nov 18, 2011 04:42 PM
chrowen
2004 - 2008 F150
Aug 9, 2011 11:04 AM
Teamfour
1997 - 2003 F150
Jun 15, 2001 10:28 PM
