2010 F150 XLT Caliper Problems
Old 04-03-2014, 08:47 PM
JNewren's Avatar
JNewren
JNewren is offline
I recently replaced my pads and rotors. The driver side was no problem, but on the passenger side, when I was finished, the caliper was rubbing up against the rim of the tire. I took both tires off to compare the differences, I noticed that my passenger side caliper is not going down as deep on the pads as the driver side. The caliper on the passenger side depressed with no problems and had no problems fitting over the pads. Whats really confusing is that all of my bolt holes line up. Any suggestions????
Old 07-02-2014, 08:35 PM
6.0to5.0's Avatar
6.0to5.0
6.0to5.0 is offline
Old 07-02-2014, 09:25 PM
efx4's Avatar
efx4
efx4 is offline
Good info!
Old 07-22-2014, 09:10 AM
6.0to5.0's Avatar
6.0to5.0
6.0to5.0 is offline
Just to clarify, credit goes to makuloco2000 for the video, he's a member on here as well!
Old 07-22-2014, 05:53 PM
royb's Avatar
royb
royb is offline
backwards pads as the video shows but it you just want to know but not watch
Old 07-24-2014, 12:55 PM
Caleb_Maldo's Avatar
Caleb_Maldo
Caleb_Maldo is offline
I have a 2010 F150 XLT 4X4, and I took my truck mudding the other. After I cleaned the truck off I noticed a noise that sounded like grinding/glass in a blender coming from what I think is the front passenger side. The sound only appears when I accelerate my truck, not when I press the break or take my foot off of the gas pedal. Also the sound goes away when I put my truck in 4 high and 4 low. Any suggestions on what this could be?
Old 07-25-2014, 08:26 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
It might be time to have your dealer check this out, Caleb_Maldo. What's the current mileage?
Crystal
Old 07-27-2014, 07:43 AM
D8chumley's Avatar
D8chumley
D8chumley is offline
Resident smarta$$
Did you pull the wheel, caliper and rotor to inspect it? I'd start there, might be mud/rocks/grit where it shouldn't be
Old 07-29-2014, 09:14 AM
j.grif's Avatar
j.grif
j.grif is offline
Sounds to me like the right wheel hub is trying to engage, you may have damaged a vacuum line, when you are on the gas, vacuum is reduced and with a leaking vacuum line, it may be enough to try to engage that wheel hub into a locked position, when you let off on the gas vacuum returns and overcomes the leak, vacuum is what keeps the hubs unlocked if I am not mistaken.
Old 08-02-2014, 01:35 PM
Davedoc0001's Avatar
Davedoc0001
Davedoc0001 is offline
Front Brake pad locations
Does anyone know if there is a Ford TSB regarding the inner / outer pads?
Old 08-03-2014, 11:12 AM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
Davedoc0001 - Does anyone know if there is a Ford TSB regarding the inner / outer pads?
There's the previously noted video *Did you view it?
NOTE: FordTechMakuloco is a Ford tech' who produces ALOT of informative, helpful vid's.
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 08-03-2014, 01:17 PM
Davedoc0001
dGMJoe
Yes I did watch the video. Just wondering if it happens so frequently and can cause damage - why doesn't Ford make there Techs aware with an official bulletin?
Andrew Jarmain
2009 - 2014 F150
06-01-2018 06:50 AM
Iaff113
09-25-2015 08:23 AM
sammyhawk
1997 - 2003 F150
12-21-2010 07:44 PM
cobrapete
1997-2006 Expedition & Navigator
03-26-2009 12:45 PM
Thoth88
1983 - 2012 Ranger & B-Series
02-06-2009 11:25 PM
Quick Reply: 2010 F150 XLT Caliper Problems
