need help asap
Old Jan 13, 2010 | 11:33 AM
Wizzerd's Avatar
Wizzerd
need help asap
my 89 f 250 custom starts for about 15-45 seconds then cuts out like theres a vacum leak some where. i checked all the vacum lines and didnt seem to find a leak. what could be wrong
thanks wizzerd
Old Jan 13, 2010 | 11:38 AM
frgtflrcn's Avatar
frgtflrcn
fuel pressure?
Old Jan 13, 2010 | 11:42 AM
andym's Avatar
andym
I doubt it's fuel pressure.
Could be any one of a 100 things, but since there is virtually no useful information in the original post, the best thing to start with is pull the codes.
Old Jan 13, 2010 | 11:56 AM
Wizzerd's Avatar
Wizzerd
what kind of useful information are you looking for?
Old Jan 13, 2010 | 12:03 PM
andym's Avatar
andym
Engine, transmission, miles, recent repairs or work you did, when did the problem start, is it doing anything else out of the ordinary, any noticeable drop in mileage, etc. Basically anything that will help us diagnose the problem.
Old Jan 13, 2010 | 12:06 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
Lets start with your motor What size it is?, explain better how it cuts out. Does it just shut down, sputter to a stop, What happens if you try to give it some gas, ( in other words does it only do it a a idle or can you rev it up to 1500 or so rpm and still cut out.
Will it start right back up? or do you have to let it sit for a while.
check for codes, If no codes put a fuel pressure gauge on the rail and see what kind of pressure you get while its running, and what it does as the motor dies.
Old Jan 13, 2010 | 12:23 PM
Wizzerd's Avatar
Wizzerd
ok lets see its a japser 5.0 v8. im not suire what the tranny is its a new truck to me. its got 14000 miles on this motor, i no the tranny was rebuilt a coup[le months ago and the problem started after i brought it home and had it sit for two weeks. but thwe guy selling it had it sit for 3 months and it started right up and it ran fine. i did but replace that dash.
Old Jan 13, 2010 | 12:24 PM
Wizzerd's Avatar
Wizzerd
and it just cuts out no sputteriung anf it has to sit for about a minute and a half berfore it will start again
Old Jan 13, 2010 | 12:40 PM
andym's Avatar
andym
I wonder if the PCM is losing the signal from the PIP sensor when it warms up because of a loose wire or bad connection inside the distributor. You might or might not get a code for that, but you should definitely start with checking the codes. See fordfuelinjection.com for more info on pulling codes.
Old Jan 13, 2010 | 07:11 PM
Popa Tim's Avatar
Popa Tim
Do you get spark and fuel during the time between starts when it won't start?
I'm thinking you have no spark and its time to replace the ICM.
Old Jan 13, 2010 | 07:20 PM
powerstroke6.0's Avatar
powerstroke6.0
Can anyone help me! I'm sorry for jumping in this thread like this but my buddy has a 05 f250 6.0 and it is dumping raw fuel into the motor what could be the problem?
Old Jan 13, 2010 | 07:24 PM
andym's Avatar
andym
I'm not sure but in addition to hijacking someone else's thread you've done it in the wrong forum. Try the 6.0 forum and start your own thread.
chuck7300
Jul 18, 2014 05:07 AM
Wizzerd
Jun 18, 2010 01:01 AM
Wizzerd
16
Jan 29, 2010 07:23 PM
Wizzerd
1997 - 2003 F150
Jan 19, 2010 11:41 PM
