vacume leak
Old Jul 16, 2014 | 07:04 PM
chuck7300's Avatar
chuck7300
vacume leak
No 4x4 checked for vacume leak at hubs no leak where else to look.
Old Jul 16, 2014 | 08:32 PM
whitetmw's Avatar
whitetmw
Pulse Vacuum Solenoid
Old Jul 16, 2014 | 08:58 PM
nlemerise's Avatar
nlemerise
Does the vacuum pump come on when you turn the key on?
Old Jul 17, 2014 | 07:41 AM
Tugly's Avatar
Tugly
I have a Mity Vac with a gauge. I unplugged components and vacuum-checked hoses until I found the culprit.
Old Jul 18, 2014 | 05:07 AM
David7.3's Avatar
David7.3
The system works by receiving vacuum pulses. One pulse pulls the the hubs in and locks, then when you hit the button again the solenoid sends two vacuum pulses to release the hub. These hubs are not servicable. but I have taken them apart and got them to work, the vucuum pump, chamber and solenoid are pretty reliable it's the hubs that are the problem, and not so much the inner and outer seals. the hub it self uses two plastic clips that hold the hub in lock mode, they wear and separate over time. I know the hubs are expensive!!!!!!!! but all the ones I worked on that turned out to be the problem. I have a toolbox full off outer and inner seals, just like the shift tube bushings. Fords have there problems but, still would not trade mine for a chevy anyday.
RV_Tech
Nov 4, 2016 02:19 PM
rmilchman
Aug 18, 2011 03:46 AM
bulla
Jul 2, 2011 01:17 PM
harstad23
Dec 15, 2007 11:25 PM
