Found out more things, Please help
Old Jan 11, 2010 | 05:00 PM
starmilt's Avatar
starmilt
If one is up your alt is doing its job but the cable connecting them isn't getting the juice from the passenger side where it enters to the drivers side. Now if you checked them right after you have been driving it the drivers side battery could be lower if it is bad but if it has sat a few hours and the cable is good and making contact they will be close to the same as the bad one will drag down the good one.
Old Jan 11, 2010 | 05:04 PM
87crewdually's Avatar
87crewdually
If you had checked them as posted in post #2 you would have it this figured out sooner. We are all here to help but there's steps to follow and we need accurate feedback to help you.
It sounds you may have a shorted cell in the low battery.
Old Jan 11, 2010 | 05:42 PM
ebaugh90's Avatar
ebaugh90
Thanks man, I appreciate it. Ill be doing some more stuff to it in the morning and let yall know what happens
Old Jan 13, 2010 | 03:21 PM
ebaugh90's Avatar
ebaugh90
UPDATE: The cable that connects my starter solenoid to the starter, it melted off and detached itself from the solenoid. Any one know what may have caused this? I got a new starter, im about to install it, then ill be testing my glow plugs to see if their bad or if my GlowPlug control box isnt working right.
Old Jan 13, 2010 | 03:37 PM
wreckinball's Avatar
wreckinball
Mine had corroded off completely so it might not be melted as much as just old and dead. See below!
Old Jan 13, 2010 | 04:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
interesting.
glad i replaced that line with 4 gauge tinned marine wire too.
good lord wreckinball,
you weren't kidding in your thread, where you said you have a bad oil leak.
Old Jan 13, 2010 | 04:42 PM
ebaugh90's Avatar
ebaugh90
My trucks old starter looks exactly like that, Oil and everything. My rear main seal leaks. And my cable looked just like your man, corroded, i though it was melted. But also, the bolt that holds that wire on the solenoid broke off inside the solenoid.
Old Jan 13, 2010 | 08:26 PM
ebaugh90's Avatar
ebaugh90
i replaced the starter, and now my truck starts up almost brand new. Im very happy, and it only took about 10 minutes to get the starter out, and about 5 to get it back in
Old Jan 13, 2010 | 08:47 PM
starmilt's Avatar
starmilt
Dayum superman you didn't leave the top bolt out did you.lol
Old Jan 13, 2010 | 09:27 PM
wreckinball
Originally Posted by FORDF250HDXLT
interesting.
thats the old engine! hhaha nice one!
Old Jan 13, 2010 | 09:30 PM
wreckinball
i had the same results, started like a champ. the ford techs laughed when they saw it because it was the starter that was installed with the last engine when it was new. It was one of the oldest working starters i have ever heard of. It started that last truck like ****e sandwich in a dirty sock, yes i just said that! hahahah
Old Jan 14, 2010 | 10:46 AM
Dave Sponaugle's Avatar
Dave Sponaugle
OK you next stop should be at a parts house, disconnect the battery cables and have both batteries load tested.
Sounds like you have a bad battery or the connection inside the battery cable clamps where the conductors hook to the clamps is bad.
The corrosion I was talking about is inside the cables and clamps, the only way to see it is cut the clamps open where the cable connects.
Bad cables can cause excess heat and may be partly responsible for the wire burning off of the solenoid.
dphracker
16
Apr 23, 2012 10:59 PM
49er_rs
1997 - 2003 F150
Oct 22, 2007 06:22 PM
inline6 Red Neck
Oct 12, 2006 04:56 AM
aguylookingforadvice
23
Apr 19, 2006 07:27 AM
royale5
Dec 5, 2005 01:26 PM
