Starter Help
Old Jun 22, 2006 | 11:23 AM
inline6 Red Neck's Avatar
inline6 Red Neck
Unhappy Starter Help
i went to go start my truck this mornig and it wont turn over the starter just clicks once when you turn the key i charged up the batterie and put a new starter selonied in what eles should i check
Old Oct 8, 2006 | 07:36 PM
stevenn1's Avatar
stevenn1
Truck wont crank over - starter problems
The starter clicks or the selinoid clicks?
If your engine is not locked-up, your battery has enough voltage, no loose wires anywhere, and the starter selinoid (spelling?) is new - sounds like to me your starter is locked-up. Sometimes you can beat on the starter body with a hammer while someone else is in the driver's seat holding down the key and it will start.
Or you can take starter off motor and hook jumper cables from battery to starter. Safety first - first connect the cables to the starter (- to the body, and + to the bolt) then to the battery for 1 second. If starter spins (might move around garage floor a little bit), it is good. If it does not spin, it is bad.
Inline 6, huh? You have the worlds best gas truck engine (factory timing gears, no chain....much more good stuff about that motor...) - the 300 cu in/4.9L. This one should be easy to change out the starter. Most of the external engine parts are the exact same model as for most Ford V8s of the same year.
The new vehicles have the starter and starter selinoid (spelling?) all in one unit, for example Ford 4.6/5.4 V8. And costs $130. When 1 part goes out - you must replace the whole thing. And it is a pain to get to all 3 bolts - the top 1 is the hardest. Need a 1/4" drive, flex head, fine tooth ratchet for this job. Just be glad yours is not like this. Anyways....
Thats my $0.02 worth.
Old Oct 8, 2006 | 08:04 PM
quicklook2's Avatar
quicklook2
first, try the spade connector on the starter to make sure it is making a good connection.
Old Oct 11, 2006 | 11:34 PM
Alan P's Avatar
Alan P
check the starter brushes.
My 95 F150 I6 starter had been cranking slower and finally just clicked, the battery checked out OK.
It has the 2 bolt smaller body permanent magnet gear reduction (PMGR 4") starter with 4 brushes in a holder. The pair of brushes that connect to the solenoid lead were visibly too worn down.
I saw brushes and holder listed seprately in online catalogs but could only find the PMGR brush assembly on ebay, for $13. Locally a new starter was $140, no brush kits available.
I brake cleanered the insides and regreased and it really turns good now.
Alan P
Old Oct 12, 2006 | 12:37 AM
Bdox's Avatar
Bdox
Clean all the contacting surfaces of each end of each cable. Don't forget the engine to chassis cable. Then go from there.
Old Oct 12, 2006 | 04:56 AM
lenny1carl's Avatar
lenny1carl
i just changed out the starter on my '91. it was bad per bench test. i did starter, relay, solenoid, and cable for under $150. the fact that i did it myself is an indicator how easy it was as i'm a crippled sob
Albert Sanchez
1983 - 2012 Ranger & B-Series
Oct 28, 2013 07:44 AM
chazman
Apr 23, 2011 05:21 AM
TXLynn
Apr 5, 2007 06:01 AM
hermanbrick7940
Dec 4, 2004 03:46 PM
Crumm
31
Nov 21, 2003 10:22 AM
