No Start Issue
Old Apr 21, 2012 | 08:46 PM
dphracker's Avatar
dphracker
No Start Issue
1989 Ford F250 Inline 6 Engine Manual
My truck is getting power but is not turning over, My horn works , Lights work , Just when I try to turn the key Im not getting no click or nothing.
I replaced The ground wires, My power Wire , Starter Relay , Starter And still nothing.
Any help will be much Appreciated!..
Old Apr 21, 2012 | 11:27 PM
rangergirl94's Avatar
rangergirl94
The silonoid on the inner fender you cross it with screw driver?
Old Apr 21, 2012 | 11:31 PM
minnesotafisherman's Avatar
minnesotafisherman
Check the fuel pump relay, take out the horn relay and put the fuel pump's relay in place of it. If the horn still works, relay is good.
If it doesn't turn out to be a blown fuse, then look behind the passenger side's kick panel for the fuel pump inertia switch. If the button is out, push it back down. This resolved my no start issue today.
Old Apr 21, 2012 | 11:33 PM
dphracker's Avatar
dphracker
yea i touched it with my ratchet and it sparked
Old Apr 21, 2012 | 11:36 PM
dphracker's Avatar
dphracker
alright i will try that tomorrow thanks.
Old Apr 22, 2012 | 01:36 AM
dphracker's Avatar
dphracker
OK I just went out to the truck, i smelled it smoking, found out the cylinder i got was smoking and was very hot. so i just took it off. but i think its not the furl pump switch relay, because when i turn the key i can hear it inject, and i looked in the kick panel on driver and passenger side of door didnt find no button,...... I guess tomorrow I will switch out my cylinder again and have them test the battery again that i bought. let me know if you guys have any idea thanks. much appreciated
Old Apr 22, 2012 | 06:57 AM
subford's Avatar
subford
Well everything you checked except the starter relay has nothing to do with it turning (cranking) over.
Make sure the wires are on right at the starter relay.
Also check the cranking safety switch on the side of the transmission or the clutch.
You may need a test light to find out what is going on.
Old Apr 22, 2012 | 09:52 AM
minnesotafisherman
Sounds like you have something else going on..
That inertia switch got triggered on my '92, causing it to not start. It would just keep cranking.
Old Apr 22, 2012 | 09:57 AM
subford's Avatar
subford
But he says it will not crank, the fuel system has nothing to do with that.
"but is not turning over" means it will not crank by the starting motor.
Old Apr 22, 2012 | 10:05 AM
critterf1's Avatar
critterf1
What "cylinder" are you talking about?
Old Apr 22, 2012 | 10:07 AM
subford's Avatar
subford
He is talking about the starter solenoid on the fender.
That is what spell check does with a miss spelled "solenoid" that you started with a "c".
Old Apr 22, 2012 | 10:11 AM
critterf1's Avatar
critterf1
That's what I thought. He still needs to jump the terminals to see if it turns over.
Old Apr 22, 2012 | 11:05 AM
minnesotafisherman
Yep, I had just realized that after I posted, lol.
Old Apr 22, 2012 | 11:55 AM
dphracker's Avatar
dphracker
Alright Let me go check the cranking safety switch and also I will try to jump the terminals. I drove my truck all day working, then went into the krogers, came back wouldnt even start, so let me drive there ill get back to you guys. thanks alot.
Old Apr 22, 2012 | 12:19 PM
dphracker's Avatar
dphracker
do yall think it could be the ignition switch also ? because when i turn the key it goes over but to turn it off i got to click a button on the side and turn the key all the way over, and also to turn the truck on i got to push the clutch all the way to the floor to crank. " when it did"
