4"downpipe
Old Jan 10, 2010 | 07:15 PM
going up 2!'s Avatar
going up 2!
4"downpipe
Ive been searching for a new turbo back exhaust,without the cat and wondering if they are all 3.5" downpipes? Im leaning the way of MBRP and wondering if i should stick w/ the 4" since at most ill only be adding a few bolt on parts.Ive been told the 5" is too big for basic power mods.I cant wait to hear the spool of the turbo but dont want to rush into anything.thanks from a newbie
Old Jan 10, 2010 | 07:22 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
The majority of AM exhaust offer 4" DP, but be warned fitment is an issue...doable, just not as easy...have to be concerned about contact with other components like the uppipes bellows, and tranny cooling lines.
Old Jan 10, 2010 | 07:25 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
i have Magnaflow. and whole install was an breeze. it had no fitment issues. have 4" DP and duals.
Old Jan 10, 2010 | 07:30 PM
going up 2!
i love how the response time on this forum is so quick,really appriciate it.sooo back the subject at hand.....will i really get better performance from a 4" compaired to 3.5"?is it worth the extra effort?i have some mechanical skills and fab tools but is it something id be better of not dealing w/ since im only using basic bolt-on's...programmer,intake ect...?
Old Jan 10, 2010 | 07:32 PM
going up 2!
u guys are responding faster than i can type,i like that.magnaflow,ill look into that,thanx
Old Jan 10, 2010 | 08:53 PM
jsimon724's Avatar
jsimon724
I got the Magnaflow, also. 4" DP was a bear, I don't know how anyone can get it in no problem. Sounds great, but I don't think I could ever get it back out without pulling the cab; needed a block of wood and a maul to get it in!
Sounds great wide open, but I think you'd be just as well off with a 3.5" DP, probably a whole lot easier to get in place.
Old Jan 11, 2010 | 05:52 PM
PETE'S_6.0PSD
i had more trouble getting the rest of the pipes in , my downpipe was in within 5 min. mine was 2 piece downpipe.
Old Jan 12, 2010 | 08:20 AM
dieseldrivr's Avatar
dieseldrivr
4" Magnaflow here also. I had the same experience as Pete's...downpipe went in easy.
The clamp that holds the elbow to the DP was the biggest pain for me...and I didn't get it tight enough the first time and it slipped enough to let the main pipe rub on the frame, so I had to loosen it up and re-fit...and tighten properly. No issues since (30k + miles).
Old Jan 12, 2010 | 08:25 AM
tex25025's Avatar
tex25025
Performance, doubtful, but cooler EGTs yes and that's really what you are wanting to get at particularly if you are adding a programmer into the mix.
No intake, waste of money. They don't flow more until you are well outside the usuable range of a stock or just tuned 6.0. You start adding mods like me then we can talk(FYI, there are still people that push more HP then I do and still use stock intake) and this isn't even getting into filtration issues as well.
Old Jan 12, 2010 | 10:11 AM
going up 2!
ive already dropped the intake question,heard enough guys on here pulling plenty of power from factory filters,replaced old w/ new motorcraft yesterday
Old Jan 12, 2010 | 10:13 AM
going up 2!
one more thing....4" downpipe=lower egt's,but ive been told 5" pipe from dp back is too big,will lose low end torque.correct?
Old Jan 12, 2010 | 10:26 AM
tex25025's Avatar
tex25025
Yes, that is correct. 5" is really only warrantied if you are flowing enough fuel and air to help push the exhaust through. Something that you will have to go with bigger sticks and bigger turbo to accomplish, tuning alone won't get you there.
Old Jan 13, 2010 | 05:42 PM
fruth04's Avatar
fruth04
very usedful thread for newbies...this should keep it on the board.
Ford4Life7.3
Jun 20, 2011 12:16 AM
1957F100
Mar 28, 2009 10:28 PM
nhill2090
15
Oct 22, 2007 09:26 PM
wrangler76
Feb 7, 2005 06:44 PM
PACO2280
Jan 9, 2005 01:49 AM
