Sponsored by: Real Truck
Replacing door lock actuators....diagram?
Old Jan 10, 2010 | 03:38 PM
KBEDesigns's Avatar
KBEDesigns
Question Replacing door lock actuators....diagram?
99 F350 crew cab with randomly working door locks, so I'm replacing the actuators.
I can't see up into the cavity good enough to see where the actuatos are attached, even with my dentist mirror. Does someone have a diagram or pic of where / how they attach? I have managed to disconnect the wire connector but that's it.
Old Jan 10, 2010 | 04:13 PM
ClintD1's Avatar
ClintD1
If you are having an intermittent problem with all of the door's I doubt it's the lock actuators
Old Jan 10, 2010 | 04:45 PM
ClintD1's Avatar
ClintD1
I stand corrected, after going through the threads I've found out it's more common then I thought.
https://www.ford-trucks.com/forums/4...cks-fixed.html
Old Jan 10, 2010 | 04:52 PM
KBEDesigns's Avatar
KBEDesigns
Correct. It used to be that only sometimes the other door locks wouldn't respond. Now they rarely respond or only weakly respond.
Cool fix! Thanks for the heads up to the link!
CharlesStuber85F150
May 7, 2017 07:14 AM
Stewart_H
Feb 1, 2017 07:06 PM
85MOTORSPORTXLT
Apr 4, 2016 06:19 PM
jejenkins417
Apr 29, 2012 03:33 PM
wanness
Aug 3, 2009 03:18 PM
