Replacing door lock actuators....diagram?
99 F350 crew cab with randomly working door locks, so I'm replacing the actuators.
I can't see up into the cavity good enough to see where the actuatos are attached, even with my dentist mirror. Does someone have a diagram or pic of where / how they attach? I have managed to disconnect the wire connector but that's it. |
http://i3.photobucket.com/albums/y86/clintd/lock01.jpg
If you are having an intermittent problem with all of the door's I doubt it's the lock actuators |
I stand corrected, after going through the threads I've found out it's more common then I thought.
https://www.ford-trucks.com/forums/4...cks-fixed.html |
Correct. It used to be that only sometimes the other door locks wouldn't respond. Now they rarely respond or only weakly respond.
Cool fix! Thanks for the heads up to the link! |
