1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Replacing door lock actuators....diagram?
Old 01-10-2010, 03:38 PM
KBEDesigns's Avatar
KBEDesigns
KBEDesigns is offline
Question Replacing door lock actuators....diagram?
99 F350 crew cab with randomly working door locks, so I'm replacing the actuators.
I can't see up into the cavity good enough to see where the actuatos are attached, even with my dentist mirror. Does someone have a diagram or pic of where / how they attach? I have managed to disconnect the wire connector but that's it.
Old 01-10-2010, 04:13 PM
ClintD1's Avatar
ClintD1
ClintD1 is offline
If you are having an intermittent problem with all of the door's I doubt it's the lock actuators
Old 01-10-2010, 04:45 PM
ClintD1's Avatar
ClintD1
ClintD1 is offline
I stand corrected, after going through the threads I've found out it's more common then I thought.
https://www.ford-trucks.com/forums/4...cks-fixed.html
Old 01-10-2010, 04:52 PM
KBEDesigns's Avatar
KBEDesigns
Correct. It used to be that only sometimes the other door locks wouldn't respond. Now they rarely respond or only weakly respond.
Cool fix! Thanks for the heads up to the link!
CharlesStuber85F150
05-07-2017 07:14 AM
Stewart_H
02-01-2017 07:06 PM
85MOTORSPORTXLT
04-04-2016 06:19 PM
jejenkins417
04-29-2012 03:33 PM
wanness
08-03-2009 03:18 PM
Quick Reply: Replacing door lock actuators....diagram?
