DASHDAQ ?
Old Jan 9, 2010 | 05:08 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
just bought one on ebay $328.99 w/ probe
thanks for the heads up
Old Jan 9, 2010 | 05:21 PM
ljutic ss's Avatar
ljutic ss
Good deal, If you go the dash mount make sure the dash is clean before applying the velcro brackets. Also make sure when you install the velcro adhesive pads to the dash, it's a little warmer then 25 F degrees. Nothing wants to stick when it's that cold.
Old Jul 8, 2010 | 04:29 PM
jetact's Avatar
jetact
Originally Posted by CombatMedicF-250
I have the Spartan Phalanx/DashDaq. But the DashDaq alone is a great system. More visual than the insight. and you can change it's skins. It's more expensive than the insight though. I do feel it's worth it.
With Boost and EGT you will need to get the the required analog equipment to work with the DashDaq or Insight since the OBD system in the 03-07 F-250 doesn't support that.
Other than that, I chosse the DashDaq.
PM me with anymore questions you might have about the DashDaq.
Does Dash Daq sell all of the anolog stuff to check the EGTs? Fuel Pressure?
Thanks for your help.
Old Jul 8, 2010 | 05:18 PM
bismic's Avatar
bismic
You ned to go through Phidget or Zeitronics for that
Old Jul 8, 2010 | 07:30 PM
jetact's Avatar
jetact
Thanks Bismic, I am also looking at the insight. It looks like it does the same thing and much cheaper. It looks like it is a bit smaller also to mount. the Dash daq has some cooler screens but I have plenty of bling and want something that will work well and get me the numbers I want. I already have GPS so thats not a factor in my decision. Thanks for the help.
WH 6.0
Apr 20, 2010 03:23 PM
His/Hers 6.0s
Mar 24, 2010 12:04 AM
ehgeeray
Feb 9, 2010 05:22 PM
CharGriller
21
Apr 6, 2009 09:40 PM
