4R100 Trans Service
Old Jan 7, 2010 | 01:24 PM
koski19's Avatar
koski19
4R100 Trans Service
Going to be performing the trans service soon. What trans fluid would one recommend? Planning on using Mercon V....
Thanks
Jeff
Old Jan 7, 2010 | 01:26 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You have the right plan.
Old Jan 7, 2010 | 06:28 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Have a quick look here Jeff
https://www.ford-trucks.com/forums/9...100-fluid.html
Old Jan 7, 2010 | 06:31 PM
koski19's Avatar
koski19
Great Mercon V it is. Now I have another question. I am also going to flush/exchange fluid in the power steering system. There was a link for this procedure. However, when I click the link the following pops up:
Forbidden
You don't have permission to access /power_steering_flush.php on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Do you have a new link, another link or maybe the procedure itself to pass on?
Thanks
Jeff
Old Jan 7, 2010 | 06:38 PM
ChunderDownUnder
No pictures but pretty detailed
https://www.ford-trucks.com/forums/4...id-change.html
Old Jan 7, 2010 | 07:35 PM
koski19's Avatar
koski19
Thanks for the info...Gonna get it done this weekend.
Jeff
Old Jan 7, 2010 | 09:47 PM
SGnAZ's Avatar
SGnAZ
Photos here
Power Steering Fluid Flushing Procedure For F250 Super Duty Truck
Old Jan 8, 2010 | 07:51 AM
koski19's Avatar
koski19
Thanks the infor....end of thread...
Jeff
Old Jan 8, 2010 | 11:48 AM
koski19's Avatar
koski19
Just another thought without opening a new thread. I believe Ford recommends trans service at 15,000 miles using Mercon III. Now that Mercon V is being used, can this interval be increased and if so, by how many miles?
Jeff
Old Jan 8, 2010 | 12:01 PM
miller_feed
Jeff
I believe the service recommendation from Ford is 30k. There was never a Mercon III made, only Mercon and Mercon V. You can now use Mercon V in our 4r100 trans now.
Old Jan 8, 2010 | 05:44 PM
koski19's Avatar
koski19
I stand corrected it's Mercon. I thought I read somewhere that it was 15,000 mile interval on the trans service. That's the number that comes to mind. I have had blackstone performing the oil analysis on the trans oil after taking it up the ***** from AAMCO just as bad as the stealerships.
Anyway, it has taken 3 trans oil/filter changes and the readings have really improved, along with how this trans is working. I now have 231,000 on it and it's only needed to be serviced.
Jeff
jeff14346
WTB - Parts & other
Apr 1, 2013 09:24 AM
DR Smith
Apr 27, 2012 08:05 PM
jmooremtb
Oct 7, 2006 01:09 AM
nole1
Car/truck Buying Advice
Dec 6, 2004 01:23 PM
Jeff Van Housen
Jan 25, 2002 08:23 AM
