1978 - 1996 Big Bronco
Rear Diff Ratio Question
Old Jan 7, 2010 | 09:28 AM
preppypyro's Avatar
preppypyro
Does anyone know offhand what the "common" ratios were for the gearing in the 78-79 bronco's?
Old Jan 7, 2010 | 09:51 AM
Kemicalburns's Avatar
Kemicalburns
3.50 was the most common. i am sure 4.10's was an option but rarly seen.
Whatcha thinking??
Old Jan 7, 2010 | 10:15 AM
preppypyro's Avatar
preppypyro
Oh Im just going to pick up a old bronco I bought from a relative, this weekend. The rear diff in it is supposedly busted or broken, or non working in some way or another, and was thinking I would like to find one to throw in there.
I got the whole thing for really cheap, and its not a super duper favorite vehicle of mine, but it does run supposedly pretty good and whatnot, so i figure I may try to find a diff for the time being and burn around my farm with it.
I have a 77 parts truck with a 3.00:1 (I think) diff in it, and was just wondering what was common with the broncos so I could start looking a little.
I may also trade it off on a snowmobile haha.
Old Jan 7, 2010 | 10:33 AM
Kemicalburns
just find a 9" center section with 3.50 gears and drop it in. save you from doing a complete diff change out.
Old Jan 7, 2010 | 10:39 AM
preppypyro's Avatar
preppypyro
I would most likely find the whole diff, but yeah I could do that too.
Do you know if there are any markings or numbers on the diff anywhere that would identify the ratio, or do you think a guy would have to do the revolution test to figure it out? (not like thats hard lol but im just thinking if its busted and doesnt turn the driveshaft...)
Old Jan 7, 2010 | 10:40 AM
hotrod351's Avatar
hotrod351
agree, replacing the third member is much easier and faster. in that case you can count the teeth on the old unit you take out. youll want to match it so the front and rear are matched.
Old Jan 7, 2010 | 10:58 AM
Kemicalburns
there should also be a tag on one of the center section bolts giving you ratio info. if not just do what Hotrod said.
Old Jan 7, 2010 | 06:52 PM
thecardoc's Avatar
thecardoc
Be shure to get the right splines in the axle side gears . 78-79 Broncos had 31 spline axles in them . Not all 9 inch had 31 spline, a lot had 28 spline axles.
Old Jan 7, 2010 | 07:35 PM
preppypyro's Avatar
preppypyro
Thanks for all the great info guys, Ill have a peek when I load it on the trailer this weekend, and if its warm enough I might start tearing er apart.
Old Jan 8, 2010 | 10:09 AM
AbandonedBronco's Avatar
AbandonedBronco
I thought all TRUCK 9" had 31 splines. The 28 splines were in the cars.
At least, if I was informed correctly.
Old Jan 8, 2010 | 11:49 AM
Kemicalburns
early bronco's had 28 spline.
the 78-84 ford 9" in trucks and broncos where 31spline.
264WSM
Jan 19, 2013 02:02 PM
lwclark
May 1, 2012 06:28 AM
97puller
Aug 28, 2010 06:59 AM
jrodeo
Jan 9, 2003 08:49 PM
Mil1ion
Jul 10, 2002 06:33 PM
