99 Expedition starter erratic...
Old Jul 30, 2010 | 09:09 PM
  #31
Moto Mel's Avatar
Moto Mel
Originally Posted by 1999Expy
Yep - either way (shim or replace the replacement) it's coming off
Thx.
Make sure they give you a starter for the engine that you have. I don't know if there is a diffrence in the starters between the Romeo or any other engine but there are differences elsewhere in the engines and some critical parts do not interchange.
Old Jul 30, 2010 | 10:06 PM
  #32
alloro's Avatar
alloro
Next time save yourself some headache and test it before installing that third bolt.
Old Jul 30, 2010 | 10:45 PM
  #33
1999Expy's Avatar
1999Expy
Returned to AutoZone and asked about engine-specific concerns. No info or reference to any such issues on any starters they had for my truck. Did pick up the shim- just in case.
Removed "new" (rebuilt) starter - appearance-wise, it's an identical match. BUT - the starter shaft hadn't withdrawn back into the housing after the engine started, leaving it and the attached gear protruding - and obviously engaging the flywheel with engine running. Retracted when I pushed it down (a little late!)
No obvious marks on starter gear or flywheel that I could see. To see if flywheel itself may have been the cause of noise (or now damaged) - I reinstalled the original starter (minus corroded el connection). Fired right up - no more screeching noise. Seems to me I got a bad replacement starter, and will be returning it tomorrow.
Given this - would you recommend against getting another rebuilt and pay the xtra $ for a new one? (not one to spend unnecessarily, but also don't want to get burned twice). I realize there's no guarantees anywhere, but welcome thoughts on better odds of a working part being new?
Yep - great suggestion - put original one back in with only 2.
Old Jul 30, 2010 | 11:07 PM
  #34
Moto Mel's Avatar
Moto Mel
Use your original starter and if it ever, goes bad take it to a local starter/alternator rebuilder. That way you will have the rebuilder to talk to, not a vendor. Just glad you didn't give up the original starter as a core then you would be stuck with whatever.
tassmannn
1978 - 1996 Big Bronco
Mar 3, 2016 08:18 AM
coolguy1419
Feb 23, 2016 12:13 AM
coolguy1419
Modular V8 (4.6L, 5.4L)
Feb 21, 2016 11:17 PM
chiefsfootball
20
Dec 16, 2015 10:35 AM
Brother Les
15
Jan 23, 2013 10:08 AM
