Any ballpark figure on how long it will take to remove and replace the starter for the average guy? I've got access to lift, tools, etc. Just wondering.
Once in the air, no more than 1/2 an hour. The biggest hurdle is the top bolt. Do a little more research on this site, there are many posts regarding this. I suggest using 1/4" ratchet and extensions, a ball type universal will also help.
a lift is not the average guy tool, but I'd say about two hours if you haven't done it before, top bolts are a pain
Thanks all....
got a chuckle out of the lift not being an average guy tool....and you're right.
It pays to cultivate relationships with someone who has one, I guess.
Best bud has a compleat shop, lift, and practically every tool imaginable. If only he has the magic bolt tool, I'll have it made.
Seems to me that your starter is not getting full current when you try to start. It can be due to bad connection. I had same problem with my 2000 mustang. Starter was makin clicking/engaging noise but wasn't spinning motor. I thought of battery and starter at first but then i further check into it and found rust on battery terminal connection. Because of that starter wasn't getting full current . I cleaned the terminal and and so far so good.
You can check and do different starter system test with multimeter. i have the following multimeter and manual. Simple and easy to follow instruction. You can use any multimeter
I have had both happen to me. 1ST time it was a battery, second time it was connections on the selenoid/starter. In fact the wiring on the starter loosened up twice on me. If you get underneath and look at the connections you can try and wiggle them to see if they are loose. Just dont do it with anything metal as I am sure u know they can be live wires. A small piece of wood would work well.
Good luck.
'99 Expy (265,000 mi and original starter) failed to start last nite. Found loose and corroded connection (complete with sparks!) at solenoid, visible from underneath. With help from a friend, started up as usual when the loose wire was held in place as key was turned. If only issue is the connection, has anyone fixed this by repairing the connection (replacing the wire(s) and/or spades) or does this require a complete starter/solenoid replacement? Thanks.
Thanks for the reply and link - great description of the "fun" one can have swapping out a starter .
What I meant to ask was - is there a way to repair the electrical connection and/or wire without removing the starter?
In my case, with the wire held in place, it started like normal, leading me to believe the starter is OK and the problem stemmed from the broken connection. Was trying to see if I could get away without replacing the starter. Or does this sound like a starter-issue waiting to happen?
And if I DO have to remove the starter just to make the electrical repair as you did - does it then make sense to replace it altogether (since it's the original with 265K miles on it), not to mention the headaches I've read about here from many who've had similar frustrations getting to and removing it ?
I'd appreciate any and all thoughts on this - thanks.
Yes you can repair the connection without removing the starter. In my case I was replacing a bad starter when the cable broke. Otherwise I would've left the starter in place and just repaired the cable end.
Yes again, if you do have to remove the starter I would put a new one back in. Nothing ticks me off more than doing something twice! Get one ahead of time from an online site and it will be considerably less expensive than going to a local auto parts store.
OK - made electrical repair at solenoid (fabricated a new one a la alloro's solution to broken connector - great suggestion - thx!) and decided to replace starter while there. Thanks to all suggestions here on how to access, loosen and remove all 3(!) bolts, installed replacement without "too" much trouble. BUT....
Engine started, but very noisy afterward - sounds like flywheel gears hitting starter's while engine runs. Shut down and started ignition again - same thing.
Starter fit into place very well - attached all 3 bolts finger-tight first, no forcing. Install actually went smoothly - so I don't believe it's misaligned externally. Has anyone else experienced this? Heard from someone familiar with Ford's that sometimes extra play on high mileage trucks can cause new starter teeth to remain engaged after engine starts - and that shims can help this situation. (AutoZone seems to offer something that looks like it would apply here - Help/2 pcs. starter alignment shim | Starter Shim. Universal Type | AutoZone.com_)
Anyone had to shim a replacement starter ??? Suggestions welcomed ASAP - need to get this running again. Thanks.
Anyone had to shim a replacement starter ??? Suggestions welcomed ASAP - need to get this running again. Thanks.[/quote]
Always have to shim a Chevvy starter and have never shimmed a Ford.
I think you got a starter that might have the wrong Bendix gear on it or there might be a difference according to the engine plant your engine was built in.
Did they ask for your VIN to verify the starter was correct for your engine?
Heard the same from a few GM guys about shimming. Nothing asked about VIN or engine matching - guess I should ask now! Thx for suggestion.
