If you keep it plugged in all the time I'd recommend getting an oil pan heater instead of using the block heater. A 250-300W will keep that engine warm enough that starting it will not be an issue.
Timer FTW. 1000W makes the math easy (= 1kW). Presuming a utility rate 12 cents / kWh (that's what I'm paying), a full day would cost $0.12 * 24, = $2.88 . Three hours on a timer costs $0.36 . A $10 timer will pay for itself in about four days.
