Block heater wattage?
Old Oct 27, 2006 | 10:02 PM
2001gocougs's Avatar
2001gocougs
I am going to be heading to some cold areas and am wondering what the block heater will draw? I will be using a generator to power the block heater since I will be a long way from a plug in.
Old Oct 27, 2006 | 11:44 PM
CheaperJeeper's Avatar
CheaperJeeper
Well, the general concensus on wattage seems to be "it varies".....
But they seem to run from around 500-1500 watts. Some people plug them into a timer set for a couple hours before they plan on starting their truck - rather than leave 'em powered up all night.
Here's another recent thread on the subject
https://www.ford-trucks.com/forums/5...ighlight=timer
Old Oct 28, 2006 | 11:02 AM
PLC7.3's Avatar
PLC7.3
The original Ford block heaters were 1000 watts, what do you call cold areas.
At 0*F you would require about an hours heating....... add an hour for each -15*F degrees below 0*F. I check my upper hose, if it is pressureized and warm your good to try a start. Just cycle the GPs three times before starting.......ie turn ignition on, wait until GP clicking stops, shut off and do it again.........2-3 times. Won't hurt a thing but helps significantly.
Modular V10 (6.8l)
Jan 23, 2017 06:29 PM
mblayton
Ford Truck Parts for Sale
Jan 9, 2017 05:53 PM
2gumby2
2015 - 2020 F150
Apr 6, 2016 11:30 AM
bobcf
Jan 15, 2015 06:40 PM
Bota
Nov 16, 2012 07:05 PM
