12 volt Question
Old Jan 5, 2010 | 03:51 PM
Bruker's Avatar
Bruker
Question 12 volt Question
I have a walk behind snow blower that has a 120 volt electric start and a 12 volt headlight. My questions is where does the headlight get the 12 volts from? Does is come from the 120v starter or is there a separate source somewhere within the engine shroud?
Old Jan 5, 2010 | 03:56 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Probably from a magneto
Old Jan 5, 2010 | 07:03 PM
horsepuller's Avatar
horsepuller
FTE Emeritus
120V? Do you have to plug the starter into a wall outlet?
Old Jan 5, 2010 | 07:23 PM
Bruker's Avatar
Bruker
Yep, just plug an extention cord into the wall and the other end into the starter switch.
Old Jan 5, 2010 | 07:35 PM
Lead Head's Avatar
Lead Head
The engine's magneto has a separate lighting coil that generates electricity for the light, or it has a separate stator to generate electricity for the light. The bulb is also most likely a 6v bulb, rather a 12v.
Old Jan 5, 2010 | 09:51 PM
Keepin It Real's Avatar
Keepin It Real
It must be kind of like those lights on a bicycle that are powered by a thingamabob driven by the wheel, but I don't know how many volts that is.
BTW, does anybody know where the light goes when you turn the switch off?
Old Jan 6, 2010 | 01:32 AM
rebocardo's Avatar
rebocardo
Most of the 17 HP+ 2/4 cyl. engines come with or can be equipped with an alternator just like a car. Even had one on my Bermuda/Greens grass mower.
Old Jan 6, 2010 | 06:02 AM
ckal704's Avatar
ckal704
Yeah, you have a little stator either external to the flywheel or under the flywheel (since it is probably a Tecumseh Sno-King engine).
Old Jan 6, 2010 | 08:34 AM
hawk's Avatar
hawk
magneto ---------------------
Old Jan 6, 2010 | 11:48 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Hey, Kal!!!!
Speaking of Sno-King engines, since Tecumseh has gone out of business, where can I get a carb (preferably new) that has the adjustable idle/running jets???
I bought a 'new style' (non-adjustable) a while back, and it's a POS. (Sorry.)
ETA: The Briggs & Stratton engine on my new (figuratively speaking) snowblower has a 'lead' that is 12v. Nice to have 12v available!
Old Jan 6, 2010 | 03:58 PM
ddrumman2004's Avatar
ddrumman2004
Uhh...goes out?
Old Jan 6, 2010 | 04:59 PM
ckal704's Avatar
ckal704
Originally Posted by 00BlueOvalRanger
Hey, Kal!!!!
As far as I know, the Tecumseh parts pipeline is still flowing. I recently got an updated Tecumseh parts Cd.
Give me the numbers (just the "spec" number will do) off your engine and I should be able to find you an adjustable carb part number. Then you can price it out.
Old Jan 6, 2010 | 06:01 PM
Buck 1's Avatar
Buck 1
My light on my Toro quit. Where do I look for the magneto? Thanks!
Old Jan 7, 2010 | 09:03 AM
00BlueOvalRanger
Thanks, Kal!
There is (correction, WAS) a small engine repair shop near me, but, they closed up shop.
I took the manual w/part #s with me, and they handed me that 'non-adjustable' carb, saying that it was the replacement.
One guy said that the 'old style' carbs weren't available, any longer. (????)
That's basically why I asked.
I'll look up the info tonight, IF I can remember it!
Thanks.
Old Jan 7, 2010 | 01:18 PM
Ford_Six's Avatar
Ford_Six
More likely the bulb burned out. Check across the lamp leads with the engine running and your voltmeter set to AC.
earnhardtracer38
13
Nov 6, 2009 05:16 PM
daddio360
13
Feb 24, 2008 04:34 PM
John Scruggs
New Member Introductions
Jun 14, 2006 04:47 PM
