7.3 idi newby needs help
Old Jan 4, 2010 | 09:30 AM
  #46
Dave Sponaugle's Avatar
Dave Sponaugle
The one under the turbo is a real pain.
I use a pair of bent nose needle nose pliers to remove the electrical connection.
Then a wrench to loosen the glow plug.
Then a piece of fuel line over the top of the glow plug to turn it out and pull it out.
New one goes back in with fuel line also.
The ones more toward the front I am assuming the fuel injection lines are causing you problems.
1/4" drive socket and extension between the injection lines.
You can remove the vibration clamps on the injection lines so they can be moved slightly, but don't bend them and do replace the clamps when you are done or the lines will crack down the road from vibration.
Old Jan 4, 2010 | 10:00 AM
  #47
tangofox71's Avatar
tangofox71
i will try that got all but the back two on the passenger side out
Old Jan 4, 2010 | 10:11 AM
  #48
9473's Avatar
9473
I have found a swivel is helpful for me on #7. Those two definitely provide an opportunity to exercise patience.
Old Jan 5, 2010 | 04:59 PM
  #49
tangofox71's Avatar
tangofox71
I gave up trying to get to those too cold and my temper was starting to get the best of me. I got 6 of the 8 done and she fired right off. thanks for the help guys. i did find zd9's here in town for 13 and change.
Old Jan 5, 2010 | 05:06 PM
  #50
starmilt's Avatar
starmilt
Glad to here it Tony did you get them at o'reillys.
Old Jan 5, 2010 | 10:48 PM
  #51
tangofox71's Avatar
tangofox71
no milton, o rielly's were 14.99 i got them at bumper to bumper for 13.25. i only broke the vacumm line going to my turbo gauge. it was so cold that plastic just snapped i barley touched it. where does that attach to the turbo i couldnt find it. thanks again for all your help and tips to keep me on the road for a long time. next oil change i will clean the cd canister with gas like you said.
Old Jan 5, 2010 | 11:25 PM
  #52
starmilt's Avatar
starmilt
Ok that line should be at a port on the intake hat right before it goes in the intake.
jgrohs54
22
Jul 19, 2017 09:36 AM
CaptainFacePunch
May 14, 2016 08:48 PM
klle5
Dec 25, 2015 11:06 PM
Torrent85
Nov 9, 2015 10:47 PM
hunterguy86
15
Jan 20, 2010 05:30 PM
