7.3 idi newby needs help
Old Jan 3, 2010 | 09:50 PM
rupejosh's Avatar
rupejosh
well thats correct on one way to test them you could have used a test light though hook it to the pos side of the battery and pull the connector and touch the glowplug ,if the test light lights chances are its good.do you have a block heater? you could plug it in for a couple hours or make sure the glowplugs cant get power and give it a 1/2 second shot of starting fluid.i will get cussed at for saying that i can see it already.anyway when i said half second squirt that is MAX ether will fire at a very low temp. too much you can bend the rods and thats BEST case scenario.so consider that my disclaimer.lol i have used ether on mine with no adverse effects ,other people have done some real damage though.
Old Jan 3, 2010 | 09:53 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
RUPE! RUPE! RUPE! lol just messing.
Old Jan 3, 2010 | 09:54 PM
87crewdually's Avatar
87crewdually
Obviously YES you have bad glow plugs. If you hook them up out of the engine like you had described they would glow cherry pretty quick if they were good. If you found 3 dead ones already do yourself a favor and get 8 new ones and wind them in. Get only Beru ZD9's from a website or Ford/motorcraft directly. Autolites will burn up and break off inside the head.
Old Jan 3, 2010 | 09:55 PM
rupejosh's Avatar
rupejosh
and replace all 8 ,motorcraft/beru plugs are the only ones i havent heard problems from
Old Jan 3, 2010 | 09:59 PM
tangofox71's Avatar
tangofox71
i have a block header but not sure it is working the plug as of about 3 days ago didnt feel warm where the ex cord and the heater cord connect like it did before. the ex cord has power i tested it a shop light. not sure about the three pronged plug on the heater cord like one thread said to test. should it jump start without the glow plugs working.
Old Jan 3, 2010 | 10:05 PM
tangofox71's Avatar
tangofox71
i was planning on going with motorcraft first i heard of beru. so i will research them. not to question your tips but to see with one is better and the cost. thanks for the replies everyone.
johnboggs21's Avatar
johnboggs21
if its a manual it could be pull started.
Some people have luck with a hair dryer in the intake to help get it started.
Old Jan 3, 2010 | 10:07 PM
87crewdually
Motorcraft and Beru are one in the same. (Motorcraft's are made by Beru)
Old Jan 3, 2010 | 10:08 PM
rupejosh's Avatar
rupejosh
oh crap i forgot about the hair dryer trick.that may work
Old Jan 3, 2010 | 10:14 PM
87crewdually
Yeah once word spreads I wonder how many $7 heat guns from Harbor Frieght will be riding around on the front seats?
Old Jan 3, 2010 | 10:35 PM
tangofox71's Avatar
tangofox71
it is an auto so what about the jump starting with the glow plugs not working. i tried jumping with no luck. new gp relay and controller the black box the relay attaches too. the new system
Old Jan 3, 2010 | 10:40 PM
tangofox71's Avatar
tangofox71
the zd9 says its for non turbos i have a 94 7.3 turbo
Old Jan 3, 2010 | 10:49 PM
  #28
johnboggs21
the turbo motors used zd9 plugs too i think
Old Jan 3, 2010 | 10:50 PM
  #29
starmilt's Avatar
starmilt
If yours is a 94 idi turbo it is zd9 if you have a 94 stroke it will be different.
Old Jan 3, 2010 | 11:05 PM
  #30
rupejosh's Avatar
rupejosh
you have a new gp relay and controller then?
