I'm going to fill up my motorhome with gas and propane.
A neighbor who works for the geographic survey claims they have evidence that indicates we will have winds between 100 and 200 mph over the ridges, so we should expect power outages. Yikes!
bruce,
thats what the weather guessers are saying for here. inxs of 100 mph. great i have a tree that doesn't like high wind or heavy snow. so we're going to have tree branches down. batten down the hatches.
I was doing some research on the zf6 transmission and I have a gripe. Why is it the Ford zf6 has a sixth gear ratio of .76:1 while the GM zf6 has a sixth gear ratio of .50:1? Also, the GM version has a removable bellhousing while fords does not.
Now that I am done ranting, I have a question. Would the GM zf6 internals interchange with the Ford zf6? Seeing as how they are both made by the same company I would guess the answer to be yes. But that is just a guess.
