Why does the Dodge 8.0L V10 get such a bad wrap?
Crankshaft-driven oil pump. Distributorless ignition (DIS). Y-block configuration where the block extends down below the crankshaft center-line (ala the Ford FE 332/352/360/390/428/428 line that came out in what, 1958?)
Interesting.
Funny how a whole bunch of things that article says was "before it's time" already existed in the Ford 4.6 modular that debuted in 1991 in the Crown Vic.
Interesting.
Interesting.
Remember that Chrysler lives in their own little world so in their mind it was before their time. :lol:
Hog out the bits on the side and you'll have a true hemi head.
Interesting.
Interesting.
Not trying to be an ***, but Chrysler used dis in 1990 on the 3.3L V6, and GM used it in 1987. So by the time the 4.6L even came out, the other manufacturers were already using it, and the Ford truck motors were no where near as advanced as dodges V10 at the time it came out. But arguing about this is pointless, the imports probably did it all first anyway.
but do you consider "distributorless" as "no distributor cap" or nothing in the distributor hole?
4V modular
Real "Hemi" head
There have been people that have hogged out some of the sides of the chambers and the result is very very close to the original Hemi heads. The had I pictured has just been lightly polished. Still has the original combustion chamber shape. The head even has the dual rocker arm setup like the original Hemi.
Here's is another picture of one:
They wanted to keep the engine somewhat compact so that required a pushrod design. So they decided why not and go with a hemi-ish design. The valves are perpendicular to each other, so total air flow is good, and flow on per port basis is also good as its a very straight shot to the valves from the port opening.
Its a good solid engine - based on the Viper V10 (although hardly anything interchanges between them). Tons of torque and a decent amount of HP.
The only issue that I've heard of was that I guess Chrysler liked to put all the coil packs together in one unit, so if one fails, you replace them all.
But like it was said, most people just opted for the Cummins instead of the V10
