pinging sound
Old Dec 22, 2009 | 10:37 PM
david schroeder's Avatar
david schroeder
pinging sound
I have this pinging sound on a 02-350SD turbo 7.3 diesel..& its noticable on idle..what has caused this ? Thanks Dave
Old Dec 23, 2009 | 12:25 AM
crazymut's Avatar
crazymut
You will have to be more descriptive. Are there any upgrades, mods, etc on your truck? Is it coming from your engine compartment? Your exhaust perhaps? I have 4 in exhaust and I have a harmonic vibration tinny noise at idle. Give us more info and someone will figure it out. Welcome to FTE
Old Dec 23, 2009 | 12:44 AM
SpringerPop's Avatar
SpringerPop
How long has it been since you had your valve covers off and properly torqued everything under there?
Pop
Old Dec 23, 2009 | 07:12 AM
david schroeder
I had the FORD techs replace a piston sensor that went out @ 84 K..sharp pingging sound comming from , near,the valve cover ..driving me nuts...runs normal..idles smooth except for the noise!
Old Dec 23, 2009 | 08:54 AM
mueckster's Avatar
mueckster
Piston sensor?
Old Dec 23, 2009 | 08:59 AM
CPUNeck's Avatar
CPUNeck
Originally Posted by mueckster
Piston sensor?
New way for Ford to get into your wallet?
OP, when did you change your fuel filter last? If the injectors aren't getting all the fuel they want, you'll get a distinctive "clink, clak" from them. Does the sound change any after the engine is up to operating temperature? X2 on the torque recommendation though.
Old Dec 23, 2009 | 09:15 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Piston sensor?? Can you be more specific on this?
Old Dec 23, 2009 | 09:18 AM
Pikachu's Avatar
Pikachu
Fuel cackle, perhaps?
Old Dec 23, 2009 | 10:42 AM
SpringerPop
David,
Welcome to FTE! We're a bunch of like-minded guys and gals that exchange information with each other to be able to best maintain and upgrade our engines and trucks with the best stuff, practices, and costs. We're glad to have you aboard.
Did changing that sensor fix the problem? If it did, what's the part number of that thing? Even if it didn't, what's the part number, so we know what they did.
Again, welcome to the party!
Pop
Old Dec 23, 2009 | 08:14 PM
david schroeder
OK..dug up the paper work ..it was the cam shaft sensor part # F7TZ-12K073-B..tecs specs.""said...they did a multi-point inspection-preformed a QCM..so..whats the pingging sound comming from..THanks.troubled here in NM'
Old Dec 23, 2009 | 08:50 PM
david schroeder
Thanks for the kind remarks.dont know where to start.......Thanks Dave
Old Dec 23, 2009 | 09:02 PM
crazymut's Avatar
crazymut
For those new to the diesel worl this is the best place I know of to start. More knowledge here than anywhere else I know of. I have been able to advise my mech budy who has been a auto mech since he was a teen, he is 50ish now, with the great info I get from this sight.
jjurva
Dec 19, 2011 10:17 AM
chicagodragon
Aug 30, 2011 08:06 PM
1978Crew
Oct 9, 2007 08:44 AM
Dave257
1983 - 2012 Ranger & B-Series
Aug 9, 2004 04:12 PM
Ranger2000
General Automotive Discussion
Feb 13, 2004 03:13 PM
