engine ping
Old Aug 19, 2011 | 03:49 PM
chicagodragon's Avatar
chicagodragon
engine ping
Hey guys, its been a while. my 97 expy is starting to ping under a load. it sounds like a bad timing type of ping. i know the timining is not adjustable (that i know of) any ideas?
Old Aug 21, 2011 | 07:18 PM
alloro's Avatar
alloro
It could be due to carbon build-up, a bad EGR valve, bad gas, or a bad knock sensor.
Old Aug 21, 2011 | 07:24 PM
chicagodragon
I haven't had a chance to put a scanner on it yet, what should I look for? It is throwing a code for a bad cat, could that have anything to do with it?
Old Aug 21, 2011 | 07:47 PM
alloro's Avatar
alloro
Yes, a bad cat can throw the air/fuel system out of whack and cause pinging.
Old Aug 22, 2011 | 05:54 PM
chicagodragon
is there a way to remove carbon without pulling the heads?
Old Aug 25, 2011 | 11:46 AM
alloro's Avatar
alloro
Yes but it's a slow process that has to be done over a long period of time by using fuel cleaners or by installing a vapor bottle.
Old Aug 26, 2011 | 06:25 PM
chicagodragon
. what about running seafoam through the vacuum line every so often? ill have the code reader on it later tonight. ill post up what i find. thanks
Old Aug 27, 2011 | 09:29 PM
chicagodragon
i only pulled 1 code. 0420-catalyst system efficiency below limit,bank one. help me out, where to begin?
Old Aug 27, 2011 | 10:41 PM
alloro's Avatar
alloro
Check into either a bad cat or a bad downstream O2 sensor on the passenger side.
Old Aug 27, 2011 | 10:51 PM
chicagodragon
Will do. I have a feeling it is the cat because it threw a code for that a while back, but it was after she filled up with ethanol. That code never came back and was the first code we had in months. Should I just throw an 02 sensor in it and see what happens?
Old Aug 28, 2011 | 01:29 PM
alloro's Avatar
alloro
IMO, it's less expensive than changing the cat.
Old Aug 30, 2011 | 08:06 PM
eemilioc's Avatar
eemilioc
I had the same problem and posted some things I did maybe it will help. The thread name is Expedition 1997 strange sound getting worse
nick_ct_203
15
Oct 31, 2014 03:46 PM
Munky
1997 - 2003 F150
48
Jul 1, 2014 05:25 PM
Jeff Dodson
29
Dec 16, 2008 09:29 AM
Dialtone
General Automotive Discussion
Mar 31, 2008 02:47 PM
MattA
1978 - 1996 Big Bronco
Apr 28, 2005 04:07 PM
