Differential/Axel Splines
Old Dec 22, 2009 | 02:41 AM
kawa's Avatar
kawa
Talking Differential/Axel Splines
Is there a way to determine the spline count on my '98 4.0 4X4 W/O pulling an axle?
Rog
Old Dec 22, 2009 | 09:29 AM
Rockledge's Avatar
Rockledge
Your '98 4.0L came with an 8.8-inch, 28-spline axle from the factory.
The only other factory Ranger spline count is 31, which is found only on '02+ FX4 Level II models.
Old Dec 22, 2009 | 12:11 PM
kawa's Avatar
kawa
Thank you Rockledge,
Merry Christmas
Old Dec 24, 2009 | 09:41 PM
ford_boy_1996's Avatar
ford_boy_1996
So my 94 2wd mazda b2300 has a 28 spline? Do you know if it has a 7.5 rear end or 8.8? I want to put a mini spool in it and i need to find ot what it has for a rear end.. Thanks for any info
Old Dec 24, 2009 | 10:10 PM
kawa's Avatar
kawa
Talking
Check for the tag on the differential bolt as well as the tag on the door. It should have a number for the diff.
Rog
Old Dec 24, 2009 | 10:20 PM
Rockledge's Avatar
Rockledge
Your '94 4-banger got the 7.5", 28 spline rear end from the factory.
As noted, if you check the axle tag, you can confirm the size and also the gear ratio.
Old Dec 25, 2009 | 10:21 PM
ford_boy_1996
Thanks for the info guys. I will check the door i for got about that
Amphihauler
Oct 1, 2016 07:54 PM
Willz74
Nov 20, 2015 09:29 PM
Cove
Nov 12, 2015 04:24 AM
Jbrown8988
Feb 15, 2010 10:01 PM
hot_bod_247
Sep 4, 2009 06:17 PM
