NEW BED
Old Apr 7, 2000 | 09:08 PM
SHOMAN92's Avatar
SHOMAN92
NEW BED
I AM LOOKING AT PUTTING A NEW BED ON MY 74 F-250 4X4. CAN ANYONE TELL ME WHAT YEARS WILL MATCH? ARE THE 4X4 AND 4X2 BEDS DIFFERENT OR CAN THEY BE INTERCHANGED?
Old Apr 8, 2000 | 12:46 AM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
NEW BED
a bed from a pickup from 73-77 will fit, as long as it is the same length as yours and the hole(s) for the gas filler neck is in the same location. 4x4 or 4x2 doesn't matter. The only other exception is certain F-250 and 350 models that had the rear axle located further towards the rear of the frame ( camper specials, etc.)
Old Apr 8, 2000 | 06:15 AM
Nathan's Avatar
Nathan
NEW BED
78-79 should fit, also. They will have the doors covering the gas fillers,though.
Nathan
Old Apr 11, 2000 | 09:35 PM
Joel_2's Avatar
Joel_2
NEW BED
I just replaced mine this weekend I have a 4X4 79 and took a bed off a 2 WD with no problems, all the holes lined up it was an easy project. Much cheaper than the body work!
Good luck
Old Apr 12, 2000 | 04:14 AM
mickelsons's Avatar
mickelsons
NEW BED
I believe that the 73-76 3/4 tos had a narrower frame than th 1/2 tons measure the distance between the mounting holes (width) other than that and the camper special 1 tons. they are the same body lines. my bed has holes drilled in it where it used to be on a differant truck that had a narrower frame.
Scott
mickelsons(No Email Addresses In Posts!)
'98 Contour
'78 F-250 4X4 SC
'69 F-250 4X2
'52 International L-110
I would rather push a Ford than drive a chevy. (like you would have to push a ford. HA)
Old Apr 12, 2000 | 06:45 AM
jowilker's Avatar
jowilker
NEW BED
Scott could you bed have come from a 4X4? That frame is narrower.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Apr 12, 2000 | 05:09 PM
mickelsons's Avatar
mickelsons
NEW BED
I am sorry I didn't specify. the '73-'76 F250 4X4 beds are narrower than the others. and yes the bed was previously on a F250 4X4 that was pre-77 I have a '78 F250 and it has the wider frame.
Scott
'98 Contour
'78 F-250 4X4 SC
'69 F-250 4X2
Old Apr 12, 2000 | 08:46 PM
Buckshot's Avatar
Buckshot
NEW BED
I have heard that there is a company that makes new beds for these trucks. I can not remember who. I almost want to say they are called tabco or tapco I am not sure.
Old Apr 13, 2000 | 04:47 PM
Ford78_302's Avatar
Ford78_302
NEW BED
Does anyone know of a good place to get a used truck box for a 78 f-150. I live in Canada so i would have to find out about shiping( that might be costly though)
Thanks
Joe
Old Apr 13, 2000 | 04:48 PM
Ford78_302's Avatar
Ford78_302
NEW BED
Does anyone know of a good place to get a used truck box for a 78 f-150. I live in Canada so i would have to find out about shiping( that might be costly though). Or can you make a wooden bottom for an exsisting box?, and how would i go about doing that?.
Thanks
Joe
Old Apr 13, 2000 | 06:12 PM
alwaysfords's Avatar
alwaysfords
NEW BED
GobblinTom
Oct 31, 2012 06:40 AM
starwriter
Feb 27, 2012 10:23 AM
bang4dabuck
Nov 6, 2011 09:42 AM
f-4x4
Dec 16, 2004 12:33 PM
77_F150_4x4
Paint & Bodywork
Nov 21, 2000 10:11 PM
