My winter project!
Old May 11, 2014 | 05:32 PM
  #106
Brown Falcon's Avatar
Brown Falcon
Looks great Don! Can't wait to see the body on there.
Old May 11, 2014 | 06:46 PM
  #107
fabmandelux's Avatar
fabmandelux
FTE Remembers
Originally Posted by Old93junk
Very funny..........I guess The 2.8 I built for my Ranger must be pushing around 200hp in this guys world.
450hp out of a 302 is entirely possible.........If you have TONS of disposable income.
Got even funnier today! Our guys just will not let it go........
Thanks Evan! More progress today. Got everything outside and ready to mount the body tomorrow! More pics.......
Old May 11, 2014 | 07:34 PM
  #108
dustybumpers's Avatar
dustybumpers
She's going to sit up there pretty good. Might need a step.
Old May 11, 2014 | 07:40 PM
  #109
Old93junk's Avatar
Old93junk
High is good.........fat girls can't jump.
Old May 11, 2014 | 07:41 PM
  #110
fabmandelux
FTE Remembers
Or two...........lol
Looks like the top of the running boards will be about 38" above the ground. I've got a powered set of steps designed that will be hidden under the running boards and will swing down sideways. I also have a pair of 3" chrome side pipes to go under the running boards...
Old May 11, 2014 | 07:45 PM
  #111
fabmandelux
FTE Remembers
Now that the chassis is out of the shop, we can put my 67 shortbed in. I need to install the 3 speed/w overdrive and make a new driveline, then finish the chrome stacks and hook up the exhaust. Then it will be my daily driver so we can start on the F-600 tow truck!
Old May 11, 2014 | 07:47 PM
  #112
Old93junk's Avatar
Old93junk
Is that the one I got you a 3 groove 300-6 crank pulley for?
Don't remember, what happened to the 94 F-150/302 you changed over to Carb from EFI?
Old May 11, 2014 | 07:49 PM
  #113
dustybumpers
Beats the sawed off aluminum step ladder out the side doors on the 70 ford van I put on the high boy frame.....
Old May 11, 2014 | 07:51 PM
  #114
fabmandelux
FTE Remembers
That would be the one Dave!
The 95 is still setting unfinished.......
Old May 11, 2014 | 07:53 PM
  #115
fabmandelux
FTE Remembers
Pictures! We need pictures!
Old May 11, 2014 | 07:55 PM
  #116
dustybumpers
Shoulda ask me for 300 parts. I have tons!!!!
I have a nice offy 4bbl intake with a holley on it, and a set of hooker headers that would love to find a new home. Nothing like opening the secondarys on a 300 with headers on it.... She'll bark!!!!
Old May 11, 2014 | 07:56 PM
  #117
dustybumpers
Have them in an album. one of these days I need to take some time and scan all those into my external hard drive.
Old May 11, 2014 | 07:59 PM
  #118
Old93junk's Avatar
Old93junk
Whats holding it up?
Bring it with you!, I got a guy at work who I am trying to walk through durasparking his 84 F-250 300-6, it has that HORRIBLE EECII TFI feedback carb set-up that is in it's last gasps, he is looking for headers and at least a 2bbl manifold.
Old May 11, 2014 | 08:02 PM
  #119
fabmandelux
FTE Remembers
I rebuilt the 300/6 and installed a Offy manifold and 390 Holley and a set of duel outlet headers. I just needed the 3 groove pulley so I could use the power steering and Dave found me one. I had a 3 speed installed but found a 3 speed /w overdrive I'm putting in now. The shortbed came with notched front for stacks, and I've got a pair of 2" chrome side pipes that will work good for stacks! Should only take a day or two to get it ready. It's got sheet metal parts from 3 different rigs, so we'll give it a quick sand and put a coat of primer on. Won't paint it till next summer...
Old May 11, 2014 | 08:04 PM
  #120
dustybumpers
Actually duraspark is plug and play if you go with a gm hei modual. I'll dig out the how to thread I wrote on it a while back. He can also use a carter single bbl carb off your 67 on the stock intake, just has to oblong the mounting bolts in the carb base.
The best and fastest exhaust is the efi manifold, and a cat conversion pipe, I'll dig the part # out for that. He'll have to grind a spot off the alt bracket.
I can ship the offy and carb out ther no prob, and even a stock manifold set, but the headers would cost more than they are worth to ship
